    [MMM-MQTTbridge] A module to publish and receive MQTT messages
    16 Posts 3 Posters 4.8k Views 3 Watching
    • Cr4z33C Offline
      Cr4z33 @wishmaster270
      @wishmaster270 said in [MMM-MQTTbridge] A module to publish and receive MQTT messages:
      @Cr4z33 Hi,
      think I found the problem.
      You need to send streamX as value where X is the number of the stream in the configuration of MMM-RTSPStream.
      You will need to configure the camera information in the MMM-RTSPStream module and only will be able to start the stream by notification
      Hi mate I am coming back after a long time because real life was very busy lately and I could get back at this only in the last 2 days.
      So based on your reply I set mqttDictionary.js like this
      var mqttHook = [
          mqttTopic: "zigbee2mqtt/BTicino F20T60A",
          mqttPayload: [
              payloadValue: "",
              mqttNotiCmd: ["POWERMETER"],
              mqttPayload: ""
            mqttTopic: "DahuaVTO/VideoTalkLog/Event",
            mqttPayload: [
                 jsonpath: "Action",
                 conditions: [
                               type: "eq",
                               value: "Pulse"
                mqttNotiCmd: ["videocitofono"]
      var mqttNotiCommands = [
          commandId: "POWERMETER",
          notiID: "POWERMETER_VALUES",
            commandId: "videocitofono",
            notiID: "RTSP-PLAY",
            notiPayload: "stream1"
      module.exports = { mqttHook,  mqttNotiCommands};
      Although stream1 is the one and only stream used in MMM-RTSPStream I still get no playback when the doorbell button is pressed, but if I start the stream by clicking on the module’s playback button then it works.
      I paste here also the PM2 log line (note that sensitive data have been censored) when the doorbell button is pressed:
      [23.09.2024 12:36.03.216] [LOG]   [MQTT bridge] MQTT message received. Topic: DahuaVTO/VideoTalkLog/Event, message: {
          "Action": "Pulse",
          "Code": "VideoTalkLog",
          "Data": {
              "EndState": "Missed",
              "LocalNumber": "9901",
              "LocaleTime": "2024-09-23 12:36:03",
              "RealUTC": 1727087763,
              "TalkTime": 0,
              "UTC": 1727091363.0
          "Index": 0,
          "deviceType": "DHI-VTO2202F-P-S2",
          "serialNumber": "*******"
      Can you please see why it’s not working yet? 🙏🏼
      • wishmaster270W Offline
        wishmaster270 Module Developer @Cr4z33
        @Cr4z33 Hi and welcome back.
        I still do not have a glue about the RTSP module.
        Can you please provide your RTSP config. I try to reproduce the problem but do not have much time to test at the moment.
        Cr4z33C 1 Reply Last reply Reply Quote 1
        • Cr4z33C Offline
          @wishmaster270 here is the code of my RTSPStream module thanks. 🙂
          I replaced my video doorbell RTSP stream with some testing live HTTPS camera one as I couldn’t find a working RTSP testing stream.
          Take your time as long as it takes. 👍🏼
          			module: "MMM-RTSPStream",
          			position: "middle_center",
          			disabled: false,
          				autoStart: false,
          				rotateStreams: true,
          				rotateStreamTimeout: 10,
          				moduleWidth: 500,
          				moduleHeight: 281,
          				localPlayer: 'vlc',
          				moduleOffset: { left: -170, top: -125 },
          				remotePlayer: 'ffmpeg',
          				showSnapWhenPaused: false,
          				remoteSnaps: false,
          				shutdownDelay: 12,
          				stream1: {
          						url: 'https://99663300.hopto.org:19526/Jpeg/1?authToken=7f9c4ca8-e776-40c9-b242-6882b7b4775e&1727250645145',
          						frameRate: 'undefined',
          						width: 500,
          						height: 281,
          						muted: true,
          						ffmpegPort: 9999,
          1 Reply Last reply Reply Quote -1
          • Cr4z33C Offline
            Cr4z33
            @wishmaster270 after I left this project abandoned for almost 1 year I went back to it, but I still can’t get it to work. 🥲
            To resume what I want to achieve is to have MMM-RTSPStream popping up a live doorbell video feed on my smart mirror whenever someone presses the button.
            The interested MQTT line is
            2025-04-16 10:30:07,536 INFO __main__ Publishing MQTT message DahuaVTO/Invite/Event: {'Action': 'Pulse', 'Code': 'Invite', 'Data': {'CallID': '2', 'IsEncryptedStream': False, 'LocaleTime': '2025-04-16 10:30:07', 'LockNum': 2, 'RealUTC': 1744792207, 'SupportPaas': False, 'TCPPort': 37777, 'UTC': 1744795807.0, 'UserID': '101'}, 'Index': 0, 'deviceType': 'DHI-VTO3311Q-WP', 'serialNumber': '********'}
            I therefore edited my current mqttDictionary.js by adding
            var mqttHook = [
                mqttPayload: [
                    payloadValue: "",
                    mqttPayload: ""
                  mqttTopic: "DahuaVTO/Invite/Event",
                  mqttPayload: [
                       jsonpath: "Action",
                       conditions: [
                                     type: "eq",
                                     value: "Pulse"
            I then edited in config.js the lines related to the MMM-RTSPStream module like this
            			disabled: false,
            				autoStart: false,
            				moduleWidth: 500,
            				moduleHeight: 281,
            				localPlayer: 'vlc',
            				remoteSnaps: false,
            				shutdownDelay: 12,
            				stream1: {
            						url: 'rtsp://username:password@ipaddress/cam/realmonitor?channel=1&subtype=1#backchannel=0',
            						width: 500,
            						height: 281,
            						muted: true,
            						ffmpegPort: 9999,
            Nothing happens when I press the doorbell button.
            Maybe we need to add some more data to mqttDictionary.js?
              @Cr4z33 Sorry, but I am very busy at the moment.
              Did you find any response of the MQTT module in your logs of MagicMirror if you enable the debug option of it?
              • Cr4z33C Offline
                @wishmaster270 hi and sorry for bothering you hehe.
                No there’s actually no sign of doorbell button pressing looking at the logs.
                All I can see is my BTicino power meter and that’s it…
                PM2 Log
