    Weather not working
    26 Posts 2 Posters 8.1k Views 2 Watching
      sdetweil @KI6UVE
      @KI6UVE lat and lng are numbers, so no quotes. either type is ok as long as they match
      • K Offline
        KI6UVE @sdetweil
        No luck with that. Should the apiVersion be in ‘ ‘ or raw? Is there a different weather app api that is easier to configure?
          sdetweil @KI6UVE
          @KI6UVE I just did this
          			module: "weather",
          				type: "current",
          			//	location: "New York",
          			//	locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				apiKey: ".....",
          				lat:30.xxxxxx,
          				lon:-97.xxxxxx
          and it worked (top right)
          and the other used locationID… with my apiKey
            @KI6UVE
            if you open the developers window using the instructions i gave before, do you see any errors?
            • K Offline
              KI6UVE @sdetweil
              Something must be wrong with my api key. I did not see the instructions for opening a developers window. Could you send again?
                sdetweil @KI6UVE
                @KI6UVE https://forum.magicmirror.builders/topic/17411/weather-not-working/9?_=1668880346563
                • K Offline
                  KI6UVE @sdetweil
                  That brought up module weather.js, Uncaught SyntaxError: unexpected token .
                    sdetweil @KI6UVE
                    @KI6UVE what line number?
                    • K Offline
                      KI6UVE @sdetweil
                        sdetweil @KI6UVE
                        @KI6UVE how did you install MM? my script or manually?
                        what version of nodejs is installed?
                        node -v
                        • 2 / 3
