    Weather not working
    26 Posts 2 Posters 10.0k Views 2 Watching
    • K
      KI6UVE @sdetweil
      That brought up module weather.js, Uncaught SyntaxError: unexpected token .
        sdetweil @KI6UVE
        @KI6UVE what line number?
        K 1 Reply Last reply
        • K
          KI6UVE @sdetweil
            sdetweil @KI6UVE
            @KI6UVE how did you install MM? my script or manually?
            what version of nodejs is installed?
            node -v
            • K
              KI6UVE @sdetweil
              Used in the install script npm install-mm from the website instructions. nodejs version is 16.18.1
                sdetweil @KI6UVE
                @KI6UVE hm… I think that is manual install …
                my scripts (listed in alternative install section)
                are here
                did u ever edit the weather.js file?
                if so, you can restore it
                git checkout modules/default/weather/weather.js
                what MM version are u running? 2.21 is current
                grep version package.json
                • K
                  KI6UVE @sdetweil
                  Never edited the weather.js file. Ran the git checkout line and it said Updated 0 paths from index. Version is 2.21.0
                  I’ll do a complete redo tomorrow with your GitHub scripts on a fresh RPi OS install. I’ll post the result here.
                    sdetweil @KI6UVE
                    @KI6UVE thx, really just need to rename the MM folder to some other name… then my script will run
                    I don’t think this is an OS problem
                    K 2 Replies Last reply
                    • K
                      KI6UVE @sdetweil
                      Thank you, I really appreciate all your help!!
                      • K
                        KI6UVE @sdetweil
                        Did fresh OS install anyway, and then ran your MM install script. Pasted my updated config file that we worked over into the new install and weather is working great. Now back to MMM-Flights.
                        So, the final analysis for anyone reading this is to use the @sdetweil Magic Mirror install script, then edit the config.js
                        The only config options for openweathermap that I used were:
                        1. Location
                        2. LocationID
                        3. apiKey (used a free one from openweathermap.org)
                        I did not have to use lat/lon or any other config options for it to work.
