    Weather not working
    26 Posts 2 Posters 10.0k Views 2 Watching
    • K
      KI6UVE @sdetweil
      I took out the endpoint line and that fixed the parsing error, but still no weather. I rechecked my api key and it is correct. Any other ideas? Thanks!!
        sdetweil @KI6UVE
        @KI6UVE open the developers window, ctrl-shift-i, then select the console tab and put weath in the filter field
        is this an openweather v 3 apikey, that u had to provide a credit card to get?
        if so, add
        apiVersion:'3.0',
        to the weather config section
        K 1 Reply Last reply
        • K
          KI6UVE @sdetweil
          No luck. I noticed you used ‘ ‘ instead of “ “ for the ‘3.0’. I used “ “ for all my other variables, such as type: “forecast”. Is that correct?
          The doc file doesn’t have any notation for how the lat/Lon is presented. Should that read…lat: ‘33.3025’ or nothing as it would imply in the doc file, I.e., lat: 33.3025
            sdetweil @KI6UVE
            @KI6UVE lat and lng are numbers, so no quotes. either type is ok as long as they match
            • K
              KI6UVE @sdetweil
              No luck with that. Should the apiVersion be in ‘ ‘ or raw? Is there a different weather app api that is easier to configure?
                sdetweil @KI6UVE
                @KI6UVE I just did this
                			module: "weather",
                				type: "current",
                			//	location: "New York",
                			//	locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				apiKey: ".....",
                				lat:30.xxxxxx,
                				lon:-97.xxxxxx
                and it worked (top right)
                and the other used locationID… with my apiKey
                  @KI6UVE
                  if you open the developers window using the instructions i gave before, do you see any errors?
                  • K
                    KI6UVE @sdetweil
                    Something must be wrong with my api key. I did not see the instructions for opening a developers window. Could you send again?
                      sdetweil @KI6UVE
                      @KI6UVE https://forum.magicmirror.builders/topic/17411/weather-not-working/9?_=1668880346563
                      • K
                        KI6UVE @sdetweil
                        That brought up module weather.js, Uncaught SyntaxError: unexpected token .
                          sdetweil @KI6UVE
                          @KI6UVE what line number?
                          • K
                            KI6UVE @sdetweil
                              sdetweil @KI6UVE
                              @KI6UVE how did you install MM? my script or manually?
                              what version of nodejs is installed?
                              node -v
                              • K
                                KI6UVE @sdetweil
                                Used in the install script npm install-mm from the website instructions. nodejs version is 16.18.1
                                  sdetweil @KI6UVE
                                  @KI6UVE hm… I think that is manual install …
                                  my scripts (listed in alternative install section)
                                  are here
                                  did u ever edit the weather.js file?
                                  if so, you can restore it
                                  git checkout modules/default/weather/weather.js
                                  what MM version are u running? 2.21 is current
                                  grep version package.json
                                  • K
                                    KI6UVE @sdetweil
                                    Never edited the weather.js file. Ran the git checkout line and it said Updated 0 paths from index. Version is 2.21.0
                                    I’ll do a complete redo tomorrow with your GitHub scripts on a fresh RPi OS install. I’ll post the result here.
                                      sdetweil @KI6UVE
                                      @KI6UVE thx, really just need to rename the MM folder to some other name… then my script will run
                                      I don’t think this is an OS problem
                                      K 2 Replies Last reply
                                      • K
                                        KI6UVE @sdetweil
                                        Thank you, I really appreciate all your help!!
                                        • K
                                          KI6UVE @sdetweil
                                          Did fresh OS install anyway, and then ran your MM install script. Pasted my updated config file that we worked over into the new install and weather is working great. Now back to MMM-Flights.
                                          So, the final analysis for anyone reading this is to use the @sdetweil Magic Mirror install script, then edit the config.js
                                          The only config options for openweathermap that I used were:
                                          1. Location
                                          2. LocationID
                                          3. apiKey (used a free one from openweathermap.org)
                                          I did not have to use lat/lon or any other config options for it to work.
