    Weather not working
    26 Posts 2 Posters 6.7k Views 2 Watching
    • K Offline
      KI6UVE @sdetweil
      I changed it from appid to apiKey and the other module names to just “weather”, but still just black space where it should be in MM. Did I miss anything else?
        sdetweil @KI6UVE
        @KI6UVE looks like weather via openweathermap takes lat/lon, not location
        i recommend reading the doc, linked to from the MM github page
        • K Offline
          KI6UVE @sdetweil
          I read that doc and I changed weatherEndpoint to “/onecall” and put in the lat and lon variables, but now I get a parsing error: unexpected token “lat”
            sdetweil @KI6UVE
            @KI6UVE don’t change the endpoint, missing a comma on the line before?
            • K Offline
              KI6UVE @sdetweil
              I took out the endpoint line and that fixed the parsing error, but still no weather. I rechecked my api key and it is correct. Any other ideas? Thanks!!
                sdetweil @KI6UVE
                @KI6UVE open the developers window, ctrl-shift-i, then select the console tab and put weath in the filter field
                is this an openweather v 3 apikey, that u had to provide a credit card to get?
                if so, add
                apiVersion:'3.0',
                to the weather config section
                • K Offline
                  KI6UVE @sdetweil
                  No luck. I noticed you used ‘ ‘ instead of “ “ for the ‘3.0’. I used “ “ for all my other variables, such as type: “forecast”. Is that correct?
                  The doc file doesn’t have any notation for how the lat/Lon is presented. Should that read…lat: ‘33.3025’ or nothing as it would imply in the doc file, I.e., lat: 33.3025
                    sdetweil @KI6UVE
                    @KI6UVE lat and lng are numbers, so no quotes. either type is ok as long as they match
                    • K Offline
                      KI6UVE @sdetweil
                      No luck with that. Should the apiVersion be in ‘ ‘ or raw? Is there a different weather app api that is easier to configure?
                        sdetweil @KI6UVE
                        @KI6UVE I just did this
                        			module: "weather",
                        				type: "current",
                        			//	location: "New York",
                        			//	locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                        				apiKey: ".....",
                        				lat:30.xxxxxx,
                        				lon:-97.xxxxxx
                        and it worked (top right)
                        and the other used locationID… with my apiKey
