    Weather not working
    26 Posts 2 Posters 8.2k Views 2 Watching
      sdetweil @KI6UVE
      @KI6UVE the doc for openweathermap provider uses a different term for the key
        sdetweil @KI6UVE
        @KI6UVE currentweather and weatherforecast have been replaced by weather, with type:‘current’ or type:‘forecast’
        • K Offline
          KI6UVE @sdetweil
          I changed it from appid to apiKey and the other module names to just “weather”, but still just black space where it should be in MM. Did I miss anything else?
            sdetweil @KI6UVE
            @KI6UVE looks like weather via openweathermap takes lat/lon, not location
            i recommend reading the doc, linked to from the MM github page
            • K Offline
              KI6UVE @sdetweil
              I read that doc and I changed weatherEndpoint to “/onecall” and put in the lat and lon variables, but now I get a parsing error: unexpected token “lat”
                sdetweil @KI6UVE
                @KI6UVE don’t change the endpoint, missing a comma on the line before?
                • K Offline
                  KI6UVE @sdetweil
                  I took out the endpoint line and that fixed the parsing error, but still no weather. I rechecked my api key and it is correct. Any other ideas? Thanks!!
                    sdetweil @KI6UVE
                    @KI6UVE open the developers window, ctrl-shift-i, then select the console tab and put weath in the filter field
                    is this an openweather v 3 apikey, that u had to provide a credit card to get?
                    if so, add
                    apiVersion:'3.0',
                    to the weather config section
                    • K Offline
                      KI6UVE @sdetweil
                      No luck. I noticed you used ‘ ‘ instead of “ “ for the ‘3.0’. I used “ “ for all my other variables, such as type: “forecast”. Is that correct?
                      The doc file doesn’t have any notation for how the lat/Lon is presented. Should that read…lat: ‘33.3025’ or nothing as it would imply in the doc file, I.e., lat: 33.3025
                        sdetweil @KI6UVE
                        @KI6UVE lat and lng are numbers, so no quotes. either type is ok as long as they match
