    Weather not working
    26 Posts 2 Posters 9.6k Views 2 Watching
      sdetweil @KI6UVE
      @KI6UVE don’t change the endpoint, missing a comma on the line before?
      • K Offline
        KI6UVE @sdetweil
        I took out the endpoint line and that fixed the parsing error, but still no weather. I rechecked my api key and it is correct. Any other ideas? Thanks!!
          sdetweil @KI6UVE
          @KI6UVE open the developers window, ctrl-shift-i, then select the console tab and put weath in the filter field
          is this an openweather v 3 apikey, that u had to provide a credit card to get?
          if so, add
          apiVersion:'3.0',
          to the weather config section
          • K Offline
            KI6UVE @sdetweil
            No luck. I noticed you used ‘ ‘ instead of “ “ for the ‘3.0’. I used “ “ for all my other variables, such as type: “forecast”. Is that correct?
            The doc file doesn’t have any notation for how the lat/Lon is presented. Should that read…lat: ‘33.3025’ or nothing as it would imply in the doc file, I.e., lat: 33.3025
              sdetweil @KI6UVE
              @KI6UVE lat and lng are numbers, so no quotes. either type is ok as long as they match
              • K Offline
                KI6UVE @sdetweil
                No luck with that. Should the apiVersion be in ‘ ‘ or raw? Is there a different weather app api that is easier to configure?
                  sdetweil @KI6UVE
                  @KI6UVE I just did this
                  			module: "weather",
                  				type: "current",
                  			//	location: "New York",
                  			//	locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  				apiKey: ".....",
                  				lat:30.xxxxxx,
                  				lon:-97.xxxxxx
                  and it worked (top right)
                  and the other used locationID… with my apiKey
                    @KI6UVE
                    if you open the developers window using the instructions i gave before, do you see any errors?
                    • K Offline
                      KI6UVE @sdetweil
                      Something must be wrong with my api key. I did not see the instructions for opening a developers window. Could you send again?
                        sdetweil @KI6UVE
                        @KI6UVE https://forum.magicmirror.builders/topic/17411/weather-not-working/9?_=1668880346563
                        • K Offline
                          KI6UVE @sdetweil
                          That brought up module weather.js, Uncaught SyntaxError: unexpected token .
                            sdetweil @KI6UVE
                            @KI6UVE what line number?
                            • K Offline
                              KI6UVE @sdetweil
                                sdetweil @KI6UVE
                                @KI6UVE how did you install MM? my script or manually?
                                what version of nodejs is installed?
                                node -v
                                • K Offline
                                  KI6UVE @sdetweil
                                  Used in the install script npm install-mm from the website instructions. nodejs version is 16.18.1
                                    sdetweil @KI6UVE
                                    @KI6UVE hm… I think that is manual install …
                                    my scripts (listed in alternative install section)
                                    are here
                                    did u ever edit the weather.js file?
                                    if so, you can restore it
                                    git checkout modules/default/weather/weather.js
                                    what MM version are u running? 2.21 is current
                                    grep version package.json
                                    • K Offline
                                      KI6UVE @sdetweil
                                      Never edited the weather.js file. Ran the git checkout line and it said Updated 0 paths from index. Version is 2.21.0
                                      I’ll do a complete redo tomorrow with your GitHub scripts on a fresh RPi OS install. I’ll post the result here.
                                        sdetweil @KI6UVE
                                        @KI6UVE thx, really just need to rename the MM folder to some other name… then my script will run
                                        I don’t think this is an OS problem
                                        K 2 Replies Last reply Reply Quote 0
                                        • K Offline
                                          KI6UVE @sdetweil
                                          Thank you, I really appreciate all your help!!
                                          • K Offline
                                            KI6UVE @sdetweil
                                            Did fresh OS install anyway, and then ran your MM install script. Pasted my updated config file that we worked over into the new install and weather is working great. Now back to MMM-Flights.
                                            So, the final analysis for anyone reading this is to use the @sdetweil Magic Mirror install script, then edit the config.js
                                            The only config options for openweathermap that I used were:
                                            1. Location
                                            2. LocationID
                                            3. apiKey (used a free one from openweathermap.org)
                                            I did not have to use lat/lon or any other config options for it to work.
