    Weather not working
    26 Posts 2 Posters 8.1k Views 2 Watching
    • K Offline
      KI6UVE @sdetweil
      Used in the install script npm install-mm from the website instructions. nodejs version is 16.18.1
        sdetweil @KI6UVE
        @KI6UVE hm… I think that is manual install …
        my scripts (listed in alternative install section)
        are here
        did u ever edit the weather.js file?
        if so, you can restore it
        cd ~/MagicMirror
        git checkout modules/default/weather/weather.js
        what MM version are u running? 2.21 is current
        cd ~/MagicMirror
        grep version package.json
        • K Offline
          KI6UVE @sdetweil
          Never edited the weather.js file. Ran the git checkout line and it said Updated 0 paths from index. Version is 2.21.0
          I’ll do a complete redo tomorrow with your GitHub scripts on a fresh RPi OS install. I’ll post the result here.
            sdetweil @KI6UVE
            @KI6UVE thx, really just need to rename the MM folder to some other name… then my script will run
            I don’t think this is an OS problem
            K 2 Replies Last reply Reply Quote 0
            • K Offline
              KI6UVE @sdetweil
              Thank you, I really appreciate all your help!!
              • K Offline
                KI6UVE @sdetweil
                Did fresh OS install anyway, and then ran your MM install script. Pasted my updated config file that we worked over into the new install and weather is working great. Now back to MMM-Flights.
                So, the final analysis for anyone reading this is to use the @sdetweil Magic Mirror install script, then edit the config.js
                The only config options for openweathermap that I used were:
                1. Location
                2. LocationID
                3. apiKey (used a free one from openweathermap.org)
                I did not have to use lat/lon or any other config options for it to work.
                • 3 / 3
