    MMM-MonthlyCalendar - repeat occurrence counts
    3 Posts 3 Posters 786 Views 3 Watching
    • W
      Whitling2k
      I’m building a digital smart calendar with MagicMirror, Raspberry Pi and a spare monitor. It’s going brilliantly, I’ve tweaked loads and solved lots of little issues I had thanks to the community and documentation.
      There is one final piece of my jigsaw puzzle that I can’t seem to solve - that is that MMM-MonthlyCalendar (KolbyJack) doesn’t show the repeating count value or title for recurring events. The in-built calendar module shows it perfectly - see screenshot - but the number value doesn’t seem to transfer over to the monthly view.
      Is this a config issue or a feature limitation, and is there anything I can do to fix it?
      I’m thinking for a brute force/hacky fix, I could add the java code to the MMM-MonthlyCalendar based on the built-in calendar (if the attributes are carried across…) (if that’s allowed!).
        sdetweil @Whitling2k
        @Whitling2k I would open an issue on the modules GitHub page to engage the author.
        BKeyportB 1 Reply Last reply
        • BKeyportB
          @sdetweil considering the last update on the module is 5 years ago…
          What I honestly would do is to look into the MMM-CalendarExt3 series of apps by @MMRIZE - he’s actively supporting his modules, and might be able to do something like that for you.
