    kolbyjack / MMM-Wallpaper & Synology
    4 Posts 2 Posters 1.5k Views 3 Watching
    • luisestradaL Offline
      luisestrada
      I love this app. I use it in my one board (I did not put a mirror but I use it as a dashboard). I am also owner of Synology, and using my pictures from a Synology album sounds like a very good idea.
      As Synology Moments was replaced with Synology Photos in DSM version 7.2, the code for using Synology Moments does not work anymore. I asked the creator a while ago but he no longer has a Synology.
      With my limited programming knowledge I tried to see if I could make it work, with no luck. I tested this information from the two links below, with no luck.
      https://community.synology.com/enu/forum/7/post/145996
      https://github.com/zeichensatz/SynologyPhotosAPI
      I wanted to post it here in case there’s someone interested in fixing/updating the code
      https://github.com/kolbyjack/MMM-Wallpaper/issues/69
      For now, my only option is to download the pictures in the Rapsberry pi.
      Thank you
        sdetweil @luisestrada
        @luisestrada looks like you could mount a Synology share on your pi to access the photos
        luisestradaL 1 Reply Last reply Reply Quote 0
          luisestrada @sdetweil
          @sdetweil The idea would be to access a Synology Photos album and read the photos from that album, so there’s no file duplications or avoiding storing pictures in multiple places
            @luisestrada I understand, using a file share and reading the data to display is exactly the same as reading thru an(other) API to display.
            I do this, but don’t ‘copy’ the images
            here the normal file system reads the image to display, instead of special code that uses a private API.
            Google drive vs GooglePhotos
            in addition, current systems provide 'link’ing ability. I use this w MMM-ImagesPhotos which only supports readingfromthe ‘uploads’ folder in the module folder. I link that to the mounted samba file server share. the module does not know the files are coming from a file server somewhere.
