    New to MM, how do I send a notification to a module?
    2 Posts 2 Posters 1.2k Views 2 Watching
      StormyWaters2021
      I have a MM set up that I am accessing via SSH. I want to use the module MMM-StopwatchTimer, which says it can be controlled via notifications, such as “START_STOPWATCH”.
      I tried reading through the documentation on the wiki, but I don’t understand how/where/what to type to get that notification into that module? Is it possible via SSH? Do I need to be in the root folder, or the MagicMirror folder, or does it matter? When it says “this.sendNotification” do I type that exactly, or do I replace “this” with the name of the module?
      Help!! Thanks in advance!
        sdetweil @StormyWaters2021
        @StormyWaters2021 notifications only cone from another module.
        but you are in luck. one of our members just created a tool to send them from a command line tool… see
        https://forum.magicmirror.builders/topic/17252/mmm-commandtonotification-run-scripts-and-send-the-outputs-as-configurable-notifications-peridocally?_=1670633661154
