    Problem with MM-MQTT module
    6 Posts 2 Posters 1.8k Views 2 Watching
    • M
      MM-Hans
      To receive MQTT messages I use Otto Paulsen’s MM-MQTT Module (https://github.com/ottopaulsen/MMM-MQTT) and that is nice software. Unfortunately, there is a problem, the output seems to be refreshed every 5 seconds, so that the text in question flashes briefly every time.
      I have created an issue on Paul’s GitHub page about this, but unfortunately no answer after a few months of waiting. Does anyone know what could be the cause? Please let me know.
      This is my code in config.js:
          			module: 'MMM-MQTT',
          			position: 'bottom_right',
      			header: 'ELEKTRA\xa0',
              		logging: false,
              		useWildcards: false,
              		mqttServers: [
                      		address: '192.168.2.155',
                      		port: '1883',
                      		subscriptions: [
                              		topic: 'MM/Accu/Lader1',
                              		label: 'Acculader 1',
      					broadcast: false,
                              		topic: 'MM/Accu/Lader2',
                              		label: 'Acculader 2',
      					broadcast: false,
                              		topic: 'Energie/power_delivered',
                              		label: 'Verbruik',
                              		suffix: 'kWh',
      					broadcast: false,
        sdetweil @MM-Hans
        @MM-Hans is the send side sending info every 5 seconds?
        M 1 Reply Last reply
        • M
          MM-Hans @sdetweil
          No Sam, both MM/Accu/ topics send every 5 minutes and Energy topic every 2.5 minute.
            sdetweil @MM-Hans
            @MM-Hans there should be messages posted to the log for every mqtt message received
            and in the developers window, ctrl-shift-i on the keyboard and select the console tab and put part of the module name in the filter field
            • M
              MM-Hans @sdetweil
              I forgot to mention that my mirror runs on a Raspberry Pi CM4 (in a Waveshare Magic Mirror). In the terminal (SSH) I can view logs with “pm2 log mm” but do not see any relevant details. CTRL-Shift-I doesn’t work if the software runs on a Raspberry, or am I mistaken?
              I just got a message from Otto Paulsen, the creator of the module, and he hadn’t heard of this problem yet. That would mean it has nothing to do with the module.
              • M
                MM-Hans @MM-Hans
                In general, “\xa0” can be used to add a space to the header, which works fine with all the modules I use. Unfortunately, that causes the mentioned problem with the MMM-MQTT module.
                As soon as I remove “\xa0” the problem is solved and the module works properly. I know, it’s strange and I can’t explain it, but it’s what I see happening in my setup.
