    Error with GooglePhotos API
    21 Posts 3 Posters 8.4k Views 3 Watching
      dum
      Hi everybody, I’m new here, as long as I arrived trying to set up a photo frame with google photos.
      I have a Raspberry PI trying to set it up, but when I reach the point to Generate Token, I find following error, any help?:
      pi-photoframe@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node generate_token.js
      [GPHOTOS:CORE] TypeError: Cannot read properties of undefined (reading '0')
      /home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:133
            throw e
          at new Auth (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:35:91)
          at GPhotos.onAuthReady (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:130:14)
          at GPhotos.generateToken (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:141:10)
          at Object.<anonymous> (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/generate_token.js:10:9)
          at Module._compile (node:internal/modules/cjs/loader:1165:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
          at Module.load (node:internal/modules/cjs/loader:1043:32)
          at Function.Module._load (node:internal/modules/cjs/loader:878:12)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          at node:internal/main/run_main_module:22:47
        sdetweil @dum
        @dum that means you selected the wrong app type on google developers console when creating the cerdentials.
        the credentials.json file must start
        {"installed":{"
        D bugsounetB 2 Replies Last reply Reply Quote 0
          dum @sdetweil
          @sdetweil Thanks for your answer.
          I select “TVs and Limited Input devices” as per the manual.
          And the credentials.json file starts with that code you write.
          I think that is not the solution or I may be still be doing something wrong.
          • bugsounetB Offline
            bugsounet Banned @sdetweil
            @sdetweil said in Error with GooglePhotos API:
            {"installed":{"
            euh installed is deprecied since one years now …
            it must start with web: { now
              sdetweil @bugsounet
              @bugsounet eh? works for me every time…
              bugsounetB 1 Reply Last reply Reply Quote 0
                @sdetweil just create new credentials and see ;)
                For old compatibility:
                  sdetweil @bugsounet
                  @bugsounet so it should have worked for either type
                    dum
                    I’m sorry. what should I do?
                    The credentials.json file is generated automatically from the google developers console… :astonished_face:
                      sdetweil @dum
                      @dum @bugsounet suggests you pick a different app type, and download a new credentials file
                        dum @sdetweil
                        @sdetweil thanks for the suggestion, I tried “desktop app” with same result.
                        the other app types require more data which I dont know how to fill.
                          sdetweil @dum
                          @dum u need to pick Web Application (1st entry)
                          need the redirect uri…
                          where on your system can the api call back to put up the verification screen
                          http://localhost:6500
                          should work… its all fake…
                            dum
                            thanks. I understand I need to write “localhost” the same as you have done.
                            But no luck. still error in generate_token:
                            [GPHOTOS:CORE] TypeError: Cannot read properties of undefined (reading 'client_id')
                                  throw e
                                at new Auth (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:35:44)
                            D S 2 Replies Last reply Reply Quote 0
                              dum @dum
                              By the way!!! I can start magic mirror… but I’m really trying to set a google photos photframe… the rest of the modules can be checked later.
                                sdetweil @dum
                                @dum said in Error with GooglePhotos API:
                                ah, you should be using
                                node generate_token_v2.js
                                from the doc at
                                https://github.com/hermanho/MMM-GooglePhotos
                                Now, open your termial
                                cd ~/MagicMirror/modules/MMM-GooglePhotos
                                  dum @sdetweil
                                  @sdetweil thanks, next step passed using “Desktop app”
                                  But now, google blocks the access even when I try to grant it:
                                    sdetweil @dum
                                    @dum u don’t want desktop. you want web
                                    D 2 Replies Last reply Reply Quote 1
                                      dum @sdetweil
                                      This post is deleted!
                                        dum @sdetweil
                                        in
                                        they say crearly and as “IMPORTANT!!” to select desktop :dizzy_face: :face_with_monocle:
                                          bugsounet Banned @dum
                                          So… select it… and apply the rules!
                                          What do you want us to tell you…
                                          (I forget that I work with the google team!)
                                          Do it yourself :)
                                            dum
                                            dear @bugsounet & @sdetweil
                                            thanks for your support, I didn’t mean to be rude, I suppose that I was frustrated for all the time I spent, while you were trying to help someone that you didn’t know and without experience :confounded_face:
                                            But finally I made it work!!!
                                            For future readers that may have my same problem, following:
                                            Finally I used “desktop app”, but the biggest issue was to allow the user:
