    Error with GooglePhotos API
    21 Posts 3 Posters 7.6k Views 3 Watching
      sdetweil @dum
      @dum that means you selected the wrong app type on google developers console when creating the cerdentials.
      the credentials.json file must start
      {"installed":{"
      D bugsounetB 2 Replies Last reply Reply Quote 0
        dum @sdetweil
        @sdetweil Thanks for your answer.
        I select “TVs and Limited Input devices” as per the manual.
        And the credentials.json file starts with that code you write.
        I think that is not the solution or I may be still be doing something wrong.
        • bugsounetB Offline
          bugsounet Banned @sdetweil
          @sdetweil said in Error with GooglePhotos API:
          {"installed":{"
          euh installed is deprecied since one years now …
          it must start with web: { now
            sdetweil @bugsounet
            @bugsounet eh? works for me every time…
            bugsounetB 1 Reply Last reply Reply Quote 0
              @sdetweil just create new credentials and see ;)
              For old compatibility:
                sdetweil @bugsounet
                @bugsounet so it should have worked for either type
                  dum
                  I’m sorry. what should I do?
                  The credentials.json file is generated automatically from the google developers console… :astonished_face:
                    sdetweil @dum
                    @dum @bugsounet suggests you pick a different app type, and download a new credentials file
                      dum @sdetweil
                      @sdetweil thanks for the suggestion, I tried “desktop app” with same result.
                      the other app types require more data which I dont know how to fill.
                        sdetweil @dum
                        @dum u need to pick Web Application (1st entry)
                        need the redirect uri…
                        where on your system can the api call back to put up the verification screen
                        http://localhost:6500
                        should work… its all fake…
