Error with GooglePhotos API
Hi everybody, I’m new here, as long as I arrived trying to set up a photo frame with google photos.
I have a Raspberry PI trying to set it up, but when I reach the point to Generate Token, I find following error, any help?:pi-photoframe@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node generate_token.js [GPHOTOS:CORE] TypeError: Cannot read properties of undefined (reading '0') /home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:133 throw e ^ TypeError: Cannot read properties of undefined (reading '0') at new Auth (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:35:91) at GPhotos.onAuthReady (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:130:14) at GPhotos.generateToken (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:141:10) at Object.<anonymous> (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/generate_token.js:10:9) at Module._compile (node:internal/modules/cjs/loader:1165:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10) at Module.load (node:internal/modules/cjs/loader:1043:32) at Function.Module._load (node:internal/modules/cjs/loader:878:12) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 -
@dum that means you selected the wrong app type on google developers console when creating the cerdentials.
the credentials.json file must start
{"installed":{" -
@sdetweil Thanks for your answer.
I select “TVs and Limited Input devices” as per the manual.
And the credentials.json file starts with that code you write.
I think that is not the solution or I may be still be doing something wrong. -
@sdetweil said in Error with GooglePhotos API:
{"installed":{"euh
installedis deprecied since one years now …
it must start withweb: {now -
@bugsounet eh? works for me every time…
@sdetweil just create new credentials and see ;)
For old compatibility:
@bugsounet so it should have worked for either type
I’m sorry. what should I do?
The credentials.json file is generated automatically from the google developers console… :astonished_face: -
@dum @bugsounet suggests you pick a different app type, and download a new credentials file
@sdetweil thanks for the suggestion, I tried “desktop app” with same result.
the other app types require more data which I dont know how to fill. -
@dum u need to pick Web Application (1st entry)
need the redirect uri…
where on your system can the api call back to put up the verification screen
should work… its all fake…
thanks. I understand I need to write “localhost” the same as you have done.
But no luck. still error in generate_token:pi-photoframe@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node generate_token.js [GPHOTOS:CORE] TypeError: Cannot read properties of undefined (reading 'client_id') /home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:133 throw e ^ TypeError: Cannot read properties of undefined (reading 'client_id') at new Auth (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:35:44) at GPhotos.onAuthReady (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:130:14) at GPhotos.generateToken (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:141:10) at Object.<anonymous> (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/generate_token.js:10:9) at Module._compile (node:internal/modules/cjs/loader:1165:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10) at Module.load (node:internal/modules/cjs/loader:1043:32) at Function.Module._load (node:internal/modules/cjs/loader:878:12) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 -
By the way!!! I can start magic mirror… but I’m really trying to set a google photos photframe… the rest of the modules can be checked later.
@dum said in Error with GooglePhotos API:
ah, you should be using
node generate_token_v2.js
from the doc at
https://github.com/hermanho/MMM-GooglePhotosNow, open your termial cd ~/MagicMirror/modules/MMM-GooglePhotos node generate_token_v2.js -
@sdetweil thanks, next step passed using “Desktop app”
But now, google blocks the access even when I try to grant it:
@dum u don’t want desktop. you want web
This post is deleted! -
in
they say crearly and as “IMPORTANT!!” to select desktop :dizzy_face: :face_with_monocle:
So… select it… and apply the rules!
What do you want us to tell you…(I forget that I work with the google team!)
Do it yourself :)
dear @bugsounet & @sdetweil
thanks for your support, I didn’t mean to be rude, I suppose that I was frustrated for all the time I spent, while you were trying to help someone that you didn’t know and without experience :confounded_face:
But finally I made it work!!!
For future readers that may have my same problem, following:
https://github.com/hermanho/MMM-GooglePhotosFinally I used “desktop app”, but the biggest issue was to allow the user:
