    Error with GooglePhotos API
    21 Posts 3 Posters 7.5k Views 3 Watching
      dum @sdetweil
      @sdetweil Thanks for your answer.
      I select “TVs and Limited Input devices” as per the manual.
      And the credentials.json file starts with that code you write.
      I think that is not the solution or I may be still be doing something wrong.
      • bugsounetB Offline
        bugsounet Banned @sdetweil
        @sdetweil said in Error with GooglePhotos API:
        the credentials.json file must start
        {"installed":{"
        euh installed is deprecied since one years now …
        it must start with web: { now
          sdetweil @bugsounet
          @bugsounet eh? works for me every time…
          bugsounetB 1 Reply Last reply Reply Quote 0
            @sdetweil just create new credentials and see ;)
            For old compatibility:
              sdetweil @bugsounet
              @bugsounet so it should have worked for either type
                dum
                I’m sorry. what should I do?
                The credentials.json file is generated automatically from the google developers console… :astonished_face:
                  sdetweil @dum
                  @dum @bugsounet suggests you pick a different app type, and download a new credentials file
                    dum @sdetweil
                    @sdetweil thanks for the suggestion, I tried “desktop app” with same result.
                    the other app types require more data which I dont know how to fill.
                      sdetweil @dum
                      @dum u need to pick Web Application (1st entry)
                      need the redirect uri…
                      where on your system can the api call back to put up the verification screen
                      http://localhost:6500
                      should work… its all fake…
                        dum
                        thanks. I understand I need to write “localhost” the same as you have done.
                        But no luck. still error in generate_token:
                        pi-photoframe@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node generate_token.js
                        [GPHOTOS:CORE] TypeError: Cannot read properties of undefined (reading 'client_id')
                        /home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:133
                              throw e
                            at new Auth (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:35:44)
                            at GPhotos.onAuthReady (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:130:14)
                            at GPhotos.generateToken (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:141:10)
                            at Object.<anonymous> (/home/pi-photoframe/MagicMirror/modules/MMM-GooglePhotos/generate_token.js:10:9)
                            at Module._compile (node:internal/modules/cjs/loader:1165:14)
                            at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            at Module.load (node:internal/modules/cjs/loader:1043:32)
                            at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                            at node:internal/main/run_main_module:22:47
                        D S 2 Replies Last reply Reply Quote 0
