    v2.22.0 | default calendar: no symbols with customEvents
    29 Posts 7 Posters 18.8k Views 7 Watching
    • kaiK Offline
      kai @sdetweil
      Hi @DaveChild, @sdetweil,
      thank you very much for your effort and your research!!!
      I’ll use @DaveChild’s prefix solution until the next release; the custom icons are now displayed within the calendar.
      Many, many thanks to you and all who so tirelessly develop the MM and keep it alive!
      May the code be with you
      -kai
        sdetweil @lmhmm
        @lmhmm you cannot just update one default module. it’s all or nothing.
        mm uses the git source code mgmt system
        this provides for different version of code concurrently.
        mm uses the master branch as the current running code
        and the develop branch to accumulate updates between releases.
        if u follow the steps in the test fixes topic
        https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
        you can pull down the develop branch and try it out.
        if you don’t know what this means and cannot try it then u have to wait. mm releases a new version every 90 days
        • karsten13K Offline
          karsten13 @sdetweil
          @sdetweil said in v2.22.0 | default calendar: no symbols with customEvents:
          the fix is not on develop because it is not merged yet but it should not take a long time …
          L 1 Reply Last reply Reply Quote 1
          • L Offline
            lmhmm @karsten13
            @karsten13 Thanks I’ll wait for the solution rather than totally mess my mirror up …
              karsten13 @lmhmm
              @lmhmm
              meanwhile the fix is merged on develop. You can try the develop branch or wait for official release in April.
              • L Offline
                lmhmm @karsten13
                @karsten13 I don’t understand your responses as they are not accompanied by any instructions so for now to avoid disaster I’ll wait thanks.
                  sdetweil @lmhmm
                  @lmhmm at the top of the troubleshooting section are instructions for using the develop branch to test fixes pending future delivery
                  if you use my upgrade script to migrate versions. it will detect develop branch being active and switch back to mater
                  • L Offline
                    lmhmm @sdetweil
                    SOLVED! Upgraded to 2.22.0 then put the fa/fas bit after symbol. It works again as before. Phweee! Just for the clueless like me!
                      jlaxh
                      Just an fyi if anyone is trying to use customEvents to alter symbols and color for a pay day event in your calendar… ask your wife not to use “$$$” as the title of the event for it. After hours of messing with the config I figured out that will alter the symbol and color for ALL events… Hopefully someone sees this and it saves them hours of frustration, especially for those of us less “coding-capable”.
