    Issues running MM on Debian 11 on Mac mini
    4 Posts 2 Posters 1.1k Views 2 Watching
      Redicaljk
      I recently installed Debian 11 on an older Mac mini without any issues. However, I am unable to run Magic Mirror.
      This is the error that occurs when I type in “npm run start”:
      raspi@raspberry:~/MagicMirror $ npm run start
      magicmirror@2.22.0 start
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      sh: 1: ./node_modules/.bin/electron: not found
      npm ERR! code 127
      npm ERR! path /home/raspi/MagicMirror
      npm ERR! command failed
      npm ERR! command sh -c DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      npm ERR! /home/raspi/.npm/_logs/2023-01-07T11_43_55_951Z-debug.log
      This is the npm and node versions:
      raspi@raspberry:~/MagicMirror $ npm --version
      7.5.2
      raspi@raspberry:~/MagicMirror $ node --version
      v12.22.12
      Any help would be most appreciated!!
        sdetweil @Redicaljk
        @Redicaljk u are on node 12. need to be 16 at least.
        if u had used my script it would have upgraded node as part of the install
        see
        you can try the upgrade script w force. it will upgrade node too
          Redicaljk @sdetweil
          @sdetweil thank you!
          I attempted to load the script but had this issue:
          Installing helper tools …
          Updating packages …
          installing correct version of node and npm, please wait
          node: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
          /usr/local/bin/node: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
          node failed to install, exiting
            sdetweil @Redicaljk
            @Redicaljk So u need to install libstdc++.so.6
            is this a lite debian? needs desktop for browser
