    Default Calendar not updating with new info
    7 Posts 2 Posters 1.6k Views 2 Watching
      dkhorse74
      MM Software = 2.21.0
      Module = Default Calendar
      Calendar = Google ical using secret address
      Issue:
      If I update the original location to a new location in my google calendar, the update of new location doesn’t reflect in MM Default Calendar module. Reboot/Restart to no avail. The default calendar still shows the original location when I had first created the event.
      I tried updating “calendarfetcher.js” using the following link:
      https://forum.magicmirror.builders/topic/9894/default-module-calendar-not-updating
      however, this did not work either. At a loss… Any advice?
        sdetweil @dkhorse74
        @dkhorse74 can u pull the ics file after your update and verify the event is there
        curl -sL your_ical_url  >somefile.txt
        then examine somefile.txt for your modified event
          dkhorse74 @sdetweil
          @sdetweil said in Default Calendar not updating with new info:
          Will do once I get back into town tomorrow. Thanks @sdetweil
            dkhorse74 @dkhorse74
            I created a test event today… I will update the location of this test event tomorrow and run the curl command to see results
              @dkhorse74 said in Default Calendar not updating with new info:
              so the issue is isolated with repeated events.
              If, for example, I enter a repeated event which is to occur every Sunday at the same location and then I edit the location of just one of those repeated events that’s where the location update fails.
              I redirected the URL output (per your suggestion) and I still see the old location in the file. Any ideas what would cause this?
                sdetweil @dkhorse74
                @dkhorse74 no. thats from the Google calendar, nothing on mm side
                  sdetweil @dkhorse74
                  @dkhorse74 do you see a unique VEVENT
                  with recurrence-id set to the base VEVENT datetime?
                  this indicates a modified recurrence
