    A module that displays Ring front door camera!
    5 Posts 4 Posters 1.7k Views 4 Watching
      anhanyoung91
      Hello, I’d like to request a module that displays the ring camera upon motion or something equivalent. It would be handy to have it pop up then disappear after an allotted time.
        magmar @anhanyoung91
        @anhanyoung91 Have you tried MMM-Ring?
        I haven’t used it myself, but it looks like what you want. As stated in the README the developer no longer maintains the code, but it might still work.
        S A 2 Replies Last reply Reply Quote 0
          sdetweil @magmar
          @magmar @anhanyoung91 it only worked for physical button presses, not motion
            anhanyoung91 @magmar
            @magmar @sdetweil i haven’t tried because it was no longer supported so I assumed it wouldn’t work. I would definitely prefer if the feed would play upon motion though…
              SdeGeata @anhanyoung91
              @anhanyoung91
              MMM-Ring, although not maintained, it still works. I am currently using it. It does indeed work with motion, but your ring needs to be configured for motion alerts. There are a couple of problems though. There is about a 10 second delay before your feed shows up on your mirror, my guests are often already in my place before the feed shows. Also, the authentication key will need to be manually updated every month.
              Have fun with the module though.
