    Nextcloud Calendar and MM
    5 Posts 4 Posters 1.8k Views 4 Watching
      scoot76
      Can someone please just tell me how to set this up? I’ve tried everything I can find but nothing works.
      I can download the ics using curl but even then it won’t use it. What am I doing wrong?
      S B S 3 Replies Last reply Reply Quote 0
        sdetweil @scoot76
        @scoot76 when u download it, what url do you use in calendar config?
        it must be in the MagicMirror folders somewhere, or linked from there
          bdream @scoot76
          @scoot76 what exactly you want to do?
          Do you want to have your NC calendar shown in your MM?
          Then please configure calendar module and include your details.
          I use default calendar module an this configuration:
          Pls note: url was given by NC in calendar
          and need to get updated to your needs
          	colored: false,
          	coloredSymbolOnly: false,
          		url: "https://<NAME>:<PASSW>@nextcloud.td/remote.php/dav/calendars/<NAME>/pers%c3%b6nlich?export"
          cheers, bdream
            MadScientist
            I had create a public share link for my calender in Nextcloud in order to use it with MM. That’s an info I have not found anywhere. My config looks like this:
                                    header: "Upcoming Birthdays",
                                            timeFormat: 'absolute',
                                            urgency: 0,
                                            getRelative: 0,
                                            showEnd: false,
                                            dateFormat: 'Do MMM',
                                            fullDayEventDateFormat: 'Do MMM',
                                                            symbol: "calendar",
                                                            url: "https://User:Password@your_url/remote.php/dav/public-calendars/xxxxxxxxxxxxx?export",
                                    titleReplace: {
                                            "Upcoming Birthdays": "",
            This is finally working for me after trying all possible URL methods before.
              scoot76 @scoot76
              @scoot76 Thanks everyone. I got it working with the public calendar link from NC. I didn’t even need to add credentials.
