    Weather based on another provider..
    18 Posts 3 Posters 17.1k Views 3 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @RedNax
      @RedNax said in Weather based on another provider..:
      I would like to know one more thing… how you get the text forecast on there too
      RedNaxR 1 Reply Last reply Reply Quote 0
      • RedNaxR Offline
        RedNax Module Developer @cowboysdude
        @cowboysdude If/when the chosen location provides any they should be displayed as per the pic…
        What’s your config?
          @RedNax this is what’s in the config.js [of course I didn’t list my key here]
                      appid: 'xxxxxxxxxxxx' //wunderground.com API key.
          I’m thinking this is what you were asking for…
          Thank you!
          Note from Moderator: Please use Markdown on code snippets for easier reading.
          • RedNaxR Offline
            @cowboysdude That config isn’t for the MMM-WunderGround module… You’re using another module that’s using Weather Underground for weather info. The forecast text functionality needs to be implemented in the module itself. Or you could of course switch to using MMM-WunderGround Which is what the above screenshot is off…
            cowboysdudeC 3 Replies Last reply Reply Quote 0
              @RedNax Thank you that explains it!!! As soon as I get the frame around it and get it set back up to work on I will be switching because I just like it!
              HUGE Thanks
                This post is deleted!
                  @RedNax Thank you for the module. I did finally get a chance to install it and it works perfectly!!!
                  Huge Thanks!! Great job!
                  • RedNaxR Offline
                    @cowboysdude :D Glad it’s working, enjoy!
