    Weather based on another provider..
    18 Posts 3 Posters 18.9k Views 3 Watching
    • mochmanM
      mochman Module Developer
      Or just get the new MagicMirror 2.0.2 that was released today. It has those changes incorporated.
      • cowboysdudeC
        cowboysdude Module Developer @mochman
        @mochman said in Weather based on another provider..:
        That’s awesome! Thank you but I just got weather underground working and I like it :)
        @cowboysdude said in Weather based on another provider..:
        I would also need the module for this and that I don’t have… I have found one but it’s not working so I’ll have to figure it out…
        Thank you!
        Found it… it’s working great!! Great job and Thank you!
        mochmanM 1 Reply Last reply
        • mochmanM
          mochman Module Developer @cowboysdude
          Yeah it does, that’s the one I use too.
          • cowboysdudeC
            @mochman but I did do my git pull to update as well!! Thank you!!!
            • cowboysdudeC
              cowboysdude Module Developer @RedNax
              @RedNax said in Weather based on another provider..:
              I would like to know one more thing… how you get the text forecast on there too
              RedNaxR 1 Reply Last reply
              • RedNaxR
                RedNax Module Developer @cowboysdude
                @cowboysdude If/when the chosen location provides any they should be displayed as per the pic…
                What’s your config?
                • cowboysdudeC
                  @RedNax this is what’s in the config.js [of course I didn’t list my key here]
                              appid: 'xxxxxxxxxxxx' //wunderground.com API key.
                  I’m thinking this is what you were asking for…
                  Thank you!
                  Note from Moderator: Please use Markdown on code snippets for easier reading.
                  • RedNaxR
                    @cowboysdude That config isn’t for the MMM-WunderGround module… You’re using another module that’s using Weather Underground for weather info. The forecast text functionality needs to be implemented in the module itself. Or you could of course switch to using MMM-WunderGround Which is what the above screenshot is off…
                    cowboysdudeC 3 Replies Last reply
                    • cowboysdudeC
                      @RedNax Thank you that explains it!!! As soon as I get the frame around it and get it set back up to work on I will be switching because I just like it!
                      HUGE Thanks
                      • cowboysdudeC
                        • cowboysdudeC
                          @RedNax Thank you for the module. I did finally get a chance to install it and it works perfectly!!!
                          Huge Thanks!! Great job!
                          • RedNaxR
                            @cowboysdude :D Glad it’s working, enjoy!
