    [MMM-SpotifyConnectUI] Error: connect ECONNREFUSED 127.0.0.1:4000
    18 Posts 4 Posters 11.7k Views 4 Watching
    • C Offline
      Camelblack
      Yes I followed the instructions from your module. I first installed Spotify Connect Web, then I installed the module and changed my config.js folder.
      However, when installing Spotify Connect web, I did get a permission issue when I was supposed to insert
      chmod a+x /etc/systemd/system/spotifyconnect.service
      I got this
      ~ $ chmod a+x /etc/systemd/system/spotifyconnect.service
      chmod: changing permissions of ‘/etc/systemd/system/spotifyconnect.service’:
      Operation not permitted
      I insterted a sudo command to continue the installations steps. Is this causing my issue?
      • CatoC Offline
        Cato Module Developer
        No sudo is required. Hmmm, did I forget that in my documentation… :-)
        • C Offline
          Camelblack @Cato
          @Cato So, despite that I get Operation not permitted I should continue to the next step? :)
          • CatoC Offline
            You say you get permission errors even when using sudo?
            • C Offline
              Camelblack @Cato
              @Cato No, after inserting sudo infront of chmod a+x /etc/systemd/system/spotifyconnect.service I did not get any permissions errors.
              When I continued I did not encounter any other errors before I tried to launch MM and got
              [MMM-SpotifyConnectUI] Notification received: CONFIG
              • CatoC Offline
                What happen if you open http://127.0.0.1:4000 in a browser on the RPi – or change the IP to the IP of the RPi and open in a browser on your own machine?
                • C Offline
                  Camelblack @Cato
                  @Cato Unfortunately even though my raspberry is assigned to a static ip I get “this site can’t be reached” on both alternatives.
                  127.0.0.1 does show up when I run ifconfig
                  lo        Link encap:Local Loopback
                            inet addr:127.0.0.1  Mask:255.0.0.0
                            inet6 addr: ::1/128 Scope:Host
                  • CatoC Offline
                    Try to start it manually:
                    cd /home/pi/spotify-connect-web
                    ./spotify-connect-web -n MAGICMIRROR -o plughw:CARD=ALSA,DEV=1
                    NB! plughw might not work for you…
                    • C Offline
                      Camelblack @Cato
                      @Cato tried that and got this error
                      Loading Spotify library...
                      min_volume_range: 0.0
                      Using libspotify_embedded version: release-esdk-1.20.0-v1.20.0-g594175d4
                      SpInit: 2
                      SpInit failed, exiting
                      • CatoC Offline
                        Then you have to contact the author of Spotify Connect Web, as this is out of the scope for my knowledge.
