    [MMM-SpotifyConnectUI] Error: connect ECONNREFUSED 127.0.0.1:4000
    18 Posts 4 Posters 12.1k Views 4 Watching
    • CatoC Offline
      Cato Module Developer
      What did you do? Did you read my documentation?
        Camelblack
        Yes I followed the instructions from your module. I first installed Spotify Connect Web, then I installed the module and changed my config.js folder.
        However, when installing Spotify Connect web, I did get a permission issue when I was supposed to insert
        chmod a+x /etc/systemd/system/spotifyconnect.service
        I got this
        ~ $ chmod a+x /etc/systemd/system/spotifyconnect.service
        chmod: changing permissions of ‘/etc/systemd/system/spotifyconnect.service’:
        Operation not permitted
        I insterted a sudo command to continue the installations steps. Is this causing my issue?
        • CatoC Offline
          No sudo is required. Hmmm, did I forget that in my documentation… :-)
            Camelblack @Cato
            @Cato So, despite that I get Operation not permitted I should continue to the next step? :)
            • CatoC Offline
              You say you get permission errors even when using sudo?
                Camelblack @Cato
                @Cato No, after inserting sudo infront of chmod a+x /etc/systemd/system/spotifyconnect.service I did not get any permissions errors.
                When I continued I did not encounter any other errors before I tried to launch MM and got
                [MMM-SpotifyConnectUI] Notification received: CONFIG
                • CatoC Offline
                  What happen if you open http://127.0.0.1:4000 in a browser on the RPi – or change the IP to the IP of the RPi and open in a browser on your own machine?
                    Camelblack @Cato
                    @Cato Unfortunately even though my raspberry is assigned to a static ip I get “this site can’t be reached” on both alternatives.
                    127.0.0.1 does show up when I run ifconfig
                    lo        Link encap:Local Loopback
                              inet addr:127.0.0.1  Mask:255.0.0.0
                              inet6 addr: ::1/128 Scope:Host
                    • CatoC Offline
                      Try to start it manually:
                      cd /home/pi/spotify-connect-web
                      ./spotify-connect-web -n MAGICMIRROR -o plughw:CARD=ALSA,DEV=1
                      NB! plughw might not work for you…
                        Camelblack @Cato
                        @Cato tried that and got this error
                        Loading Spotify library...
                        min_volume_range: 0.0
                        Using libspotify_embedded version: release-esdk-1.20.0-v1.20.0-g594175d4
                        SpInit: 2
                        SpInit failed, exiting
                        • CatoC Offline
                          Then you have to contact the author of Spotify Connect Web, as this is out of the scope for my knowledge.
                            Camelblack @Cato
                            @Cato Will do, thanks anyway!
                            Z 1 Reply Last reply Reply Quote 0
                            • Z Offline
                              zerotwenty @Camelblack
                              @Camelblack Let me know if you have any luck, I am running into the same issue.
                                Camelblack @zerotwenty
                                @zerotwenty will do. Unfortunately still no go. Please let me know if you find a fix.
                                • schlachtkreuzer6S Offline
                                  schlachtkreuzer6
                                  newer spotify connect app - raspotify works out of the box:
                                  https://github.com/dtcooper/raspotify
                                  https://discourse.osmc.tv/t/howto-spotify-connect-support-via-raspotify-librespot/38348
