    [MMM-SpotifyConnectUI] Error: connect ECONNREFUSED 127.0.0.1:4000
    18 Posts 4 Posters 12.7k Views 4 Watching
      Camelblack @Cato
      @Cato I’m sorry. I am very new to raspberry pi. To be honest; I don’t know. How to I proceed to find out which address Spotify Connect Web is installed on?
        Cato Module Developer
        What did you do? Did you read my documentation?
          Camelblack
          Yes I followed the instructions from your module. I first installed Spotify Connect Web, then I installed the module and changed my config.js folder.
          However, when installing Spotify Connect web, I did get a permission issue when I was supposed to insert
          chmod a+x /etc/systemd/system/spotifyconnect.service
          I got this
          ~ $ chmod a+x /etc/systemd/system/spotifyconnect.service
          chmod: changing permissions of ‘/etc/systemd/system/spotifyconnect.service’:
          Operation not permitted
          I insterted a sudo command to continue the installations steps. Is this causing my issue?
            No sudo is required. Hmmm, did I forget that in my documentation… :-)
              Camelblack @Cato
              @Cato So, despite that I get Operation not permitted I should continue to the next step? :)
                You say you get permission errors even when using sudo?
                  Camelblack @Cato
                  @Cato No, after inserting sudo infront of chmod a+x /etc/systemd/system/spotifyconnect.service I did not get any permissions errors.
                  When I continued I did not encounter any other errors before I tried to launch MM and got
                  [MMM-SpotifyConnectUI] Notification received: CONFIG
                    What happen if you open http://127.0.0.1:4000 in a browser on the RPi – or change the IP to the IP of the RPi and open in a browser on your own machine?
                      Camelblack @Cato
                      @Cato Unfortunately even though my raspberry is assigned to a static ip I get “this site can’t be reached” on both alternatives.
                      127.0.0.1 does show up when I run ifconfig
                      lo        Link encap:Local Loopback
                                inet addr:127.0.0.1  Mask:255.0.0.0
                                inet6 addr: ::1/128 Scope:Host
                        Try to start it manually:
                        cd /home/pi/spotify-connect-web
                        ./spotify-connect-web -n MAGICMIRROR -o plughw:CARD=ALSA,DEV=1
                        NB! plughw might not work for you…
                          Camelblack @Cato
                          @Cato tried that and got this error
                          Loading Spotify library...
                          min_volume_range: 0.0
                          Using libspotify_embedded version: release-esdk-1.20.0-v1.20.0-g594175d4
                          SpInit: 2
                          SpInit failed, exiting
                            Then you have to contact the author of Spotify Connect Web, as this is out of the scope for my knowledge.
                              Camelblack @Cato
                              @Cato Will do, thanks anyway!
                              Z 1 Reply Last reply Reply Quote 0
                              • Z Offline
                                zerotwenty @Camelblack
                                @Camelblack Let me know if you have any luck, I am running into the same issue.
                                  Camelblack @zerotwenty
                                  @zerotwenty will do. Unfortunately still no go. Please let me know if you find a fix.
                                    schlachtkreuzer6
                                    newer spotify connect app - raspotify works out of the box:
                                    https://github.com/dtcooper/raspotify
                                    https://discourse.osmc.tv/t/howto-spotify-connect-support-via-raspotify-librespot/38348
