    [MMM-SpotifyConnectUI] Error: connect ECONNREFUSED 127.0.0.1:4000
    18 Posts 4 Posters 12.9k Views 4 Watching
      Camelblack
      Hi, I get an connect ECONNREFUSED 127.0.0.1:4000 error. while trying to run the [MMM-SpotifyConnectUI] module.
      Connecting socket for: MMM-SpotifyConnectUI
      [MMM-SpotifyConnectUI] Notification received: CONFIG
      Does anyone know how to fix this?
      I can confirm that I have placed my spotify_appkey.key in the /spotify-connect-web folder, if that’s relevant.
      • CatoC
        Cato Module Developer
        Have you installed Spotify Connect Web on that address?
        C 1 Reply Last reply
          Camelblack @Cato
          @Cato I’m sorry. I am very new to raspberry pi. To be honest; I don’t know. How to I proceed to find out which address Spotify Connect Web is installed on?
          • CatoC
            What did you do? Did you read my documentation?
              Camelblack
              Yes I followed the instructions from your module. I first installed Spotify Connect Web, then I installed the module and changed my config.js folder.
              However, when installing Spotify Connect web, I did get a permission issue when I was supposed to insert
              chmod a+x /etc/systemd/system/spotifyconnect.service
              I got this
              ~ $ chmod a+x /etc/systemd/system/spotifyconnect.service
              chmod: changing permissions of ‘/etc/systemd/system/spotifyconnect.service’:
              Operation not permitted
              I insterted a sudo command to continue the installations steps. Is this causing my issue?
              • CatoC
                No sudo is required. Hmmm, did I forget that in my documentation… :-)
                  Camelblack @Cato
                  @Cato So, despite that I get Operation not permitted I should continue to the next step? :)
                  • CatoC
                    You say you get permission errors even when using sudo?
                      Camelblack @Cato
                      @Cato No, after inserting sudo infront of chmod a+x /etc/systemd/system/spotifyconnect.service I did not get any permissions errors.
                      When I continued I did not encounter any other errors before I tried to launch MM and got
                      • CatoC
                        What happen if you open http://127.0.0.1:4000 in a browser on the RPi – or change the IP to the IP of the RPi and open in a browser on your own machine?
                          Camelblack @Cato
                          @Cato Unfortunately even though my raspberry is assigned to a static ip I get “this site can’t be reached” on both alternatives.
                          127.0.0.1 does show up when I run ifconfig
                          lo        Link encap:Local Loopback
                                    inet addr:127.0.0.1  Mask:255.0.0.0
                                    inet6 addr: ::1/128 Scope:Host
                          • CatoC
                            Try to start it manually:
                            cd /home/pi/spotify-connect-web
                            ./spotify-connect-web -n MAGICMIRROR -o plughw:CARD=ALSA,DEV=1
                            NB! plughw might not work for you…
                              Camelblack @Cato
                              @Cato tried that and got this error
                              Loading Spotify library...
                              min_volume_range: 0.0
                              Using libspotify_embedded version: release-esdk-1.20.0-v1.20.0-g594175d4
                              SpInit: 2
                              SpInit failed, exiting
                              • CatoC
                                Then you have to contact the author of Spotify Connect Web, as this is out of the scope for my knowledge.
                                  Camelblack @Cato
                                  @Cato Will do, thanks anyway!
                                  Z 1 Reply Last reply
                                  • Z
                                    zerotwenty @Camelblack
                                    @Camelblack Let me know if you have any luck, I am running into the same issue.
                                      Camelblack @zerotwenty
                                      @zerotwenty will do. Unfortunately still no go. Please let me know if you find a fix.
                                      • schlachtkreuzer6S
                                        schlachtkreuzer6
                                        newer spotify connect app - raspotify works out of the box:
                                        https://github.com/dtcooper/raspotify
                                        https://discourse.osmc.tv/t/howto-spotify-connect-support-via-raspotify-librespot/38348
