[MMM-SpotifyConnectUI] Error: connect ECONNREFUSED 127.0.0.1:4000
18 Posts 4 Posters 11.1k Views 4 Watching
    Camelblack
    Hi, I get an connect ECONNREFUSED 127.0.0.1:4000 error. while trying to run the [MMM-SpotifyConnectUI] module.
    Connecting socket for: MMM-SpotifyConnectUI
    [MMM-SpotifyConnectUI] Notification received: CONFIG
    Does anyone know how to fix this?
    I can confirm that I have placed my spotify_appkey.key in the /spotify-connect-web folder, if that’s relevant.
      Cato Module Developer
      Have you installed Spotify Connect Web on that address?
      C 1 Reply Last reply Feb 14, 2017, 8:50 PM Reply Quote 0
        Camelblack @Cato
        @Cato I’m sorry. I am very new to raspberry pi. To be honest; I don’t know. How to I proceed to find out which address Spotify Connect Web is installed on?
          What did you do? Did you read my documentation?
            Camelblack
            Yes I followed the instructions from your module. I first installed Spotify Connect Web, then I installed the module and changed my config.js folder.
            However, when installing Spotify Connect web, I did get a permission issue when I was supposed to insert
            chmod a+x /etc/systemd/system/spotifyconnect.service
            I got this
            ~ $ chmod a+x /etc/systemd/system/spotifyconnect.service
            chmod: changing permissions of ‘/etc/systemd/system/spotifyconnect.service’:
            Operation not permitted
            I insterted a sudo command to continue the installations steps. Is this causing my issue?
              No sudo is required. Hmmm, did I forget that in my documentation… :-)
              C 1 Reply Last reply Feb 14, 2017, 9:21 PM Reply Quote 0
                Camelblack @Cato
                @Cato So, despite that I get Operation not permitted I should continue to the next step? :)
                  You say you get permission errors even when using sudo?
                  C 1 Reply Last reply Feb 14, 2017, 9:29 PM Reply Quote 0
                    Camelblack @Cato
                    @Cato No, after inserting sudo infront of chmod a+x /etc/systemd/system/spotifyconnect.service I did not get any permissions errors.
                    When I continued I did not encounter any other errors before I tried to launch MM and got
                      What happen if you open http://127.0.0.1:4000 in a browser on the RPi – or change the IP to the IP of the RPi and open in a browser on your own machine?
                      C 1 Reply Last reply Feb 14, 2017, 9:42 PM Reply Quote 0
