    MMM-OpenAI
    24 Posts 4 Posters 15.2k Views 4 Watching
      MMRIZE
      MMM-OpenAI
      MagicMirror module for requesting OpenAI’s API
      DISCLAIMERS :
      1. This is not a ChatGPT module; (OpenAI has not released ChatGPT API yet.). This module uses OpenAI’s API for text completion and image generation.
      2. I will not implement any voice-related features into this module directly, but if you want, you can relay those kinds of modules for your own purpose. (This module has much preparation to cooperate with other modules.)
      Screenshot
      Text Completion
      Image generation
      Features
      • Request text completions or image generation from OpenAI with detailed options
      • Activation through TelegramBot (default behaviour)
      • Activation with notification (customizable - For developing a new module or For using the current module without modification, either possible.)
      • Customizable post-process (You might not need to build an external module to handle the response for your own purpose)
      For more details
      https://github.com/MMRIZE/MMM-OpenAI
        MMRIZE
        1.1.0 (2023-03-02)
        Added : Chat API
        Chat
          Rags
          Great. Installed it and it is up and running with absolutely no effort. Thanks for this module. However, i am facing an issue of an error message “Something is wrong see the log”. So this error pops up randomly when i initiate a /chatai or a /txtai or /imgai, and i am unsure why. Is the heavy traffic of ChatGPT the reason. Also where do i check the logs.?
            MMRIZE @Rags
            @Rags
            I’ll update the modules with more kind error messages in 1-2days. Plz wait a little
              MMRIZE
              1.2.0 (2022-03-06)
              • ADDED : More kind error message (in the terminal console, the display, telegram, and the dev-console)
              • ADDED : Token usage on success in TEXT and CHAT.
              • FIXED : Reducing default max_token for chat. (Too many token limit may cause the error unexpected)
              120_1
              120_2
                MMRIZE @Rags
                @Rags
                I found it was token usage issue. I think I fixed it with the new update.
                  Rags @MMRIZE
                  @MMRIZE @MMRIZE
                  Thanks for the update. Yes now it works fine. I am not getting "something is wrong’ messages, but prompts about the token lengths whenever they exceed.
                  Thanks. I hope there will be voice integration soon.
                  M R 2 Replies Last reply Reply Quote 0
                    MMRIZE @Rags
                    @Rags
                    I will not implement Voice-feature into this module directly by myself.
                    But I believe other existing voice-related modules could be used together already.
                      MMRIZE
                      @Rags
                      Speech example: Conjunction with MMM-GoogleTTS, now it can speak.
                      https://youtu.be/daWuSfQc5Ns
                      postProcessing: (helper, resp) => {
                        let choice = resp.response?.choices[0]
                        if (choice) helper.sendNotification('TTS_SAY', choice?.message?.content ?? choice?.text)
                      S R 2 Replies Last reply Reply Quote 0
                        sdmydbr9 @MMRIZE
                        @MMRIZE a similar idea has crossed my mind. Using a Hotword detector like the one used in google assignment module to activate a listener for voice and ask for voice input and then using the input provided, get the transcript of the audio using the whisper api or something similar to get the transcript… pass on the transcript as a content in the OPENAI_REQUEST notification and then SHOW_ALERT or just read it out loud using the MMM-GoogleTTS. Just a rough sketch. I’m sure someone out here will come up with more convincing and better ideas.
                        S M 2 Replies Last reply Reply Quote -1
                          sdetweil @sdmydbr9
                          @sdmydbr9 use a GoogleAssistant recipe
                          see it’s recipies folder
                            MMRIZE @sdmydbr9
                            @sdmydbr9
                            I have a few already, like MMM-Hotword or MMM-Clap, and some…
                            Anyway new OpenAI’s Whisper looks so interesting, So I’ll make it as a STT module in a few days, hope so.
                              sdmydbr9 @sdetweil
                              @sdetweil I just meant it as a similar approach, I don’t actually want to implement the whole assistant module.
                                sdmydbr9 @MMRIZE
                                @MMRIZE I think the Hotword module is not Available anymore and the clap module, might work but it will not look as asthetic as activating with the hot word…
                                  Rags @MMRIZE
                                  @MMRIZE said in MMM-OpenAI:
                                  @Rags
                                  I am getting a syntax error in these lines can you please check.
                                    Rags @Rags
                                    @MMRIZE
                                    It’s possible that the error is caused by using optional chaining in a JavaScript version that doesn’t support it.
                                    I modified the code as below, rewriting the code without using optional chaining.
                                    postProcessing: function(helper, resp) {
                                    let choice = resp.response ? resp.response.choices[0] : undefined;
                                    if (choice) {
                                    let message = choice.message ? choice.message.content.choice.text : undefined;
                                    if (message) {
                                    helper.sendNotification(‘TTS_SAY’, message);
                                    I am not getting any syntax error now. However, there is some issue with Google TTS (unrelated I think) , as it is sending a notification as TTS_Say_Error. Google TTS API hopefully is configured correctly as no errors are thrown up during starting MM. How should i go about resolving it.
                                      MMRIZE @Rags
                                      @Rags
                                      Give me the front and backend log on error happens
                                        MMRIZE @Rags
                                        @Rags
                                        TTS_SAY notification could have more complex payload like this.
                                        .sendNotification("TTS_SAY", {
                                          content: "Live long and prosper", //text to be spoken
                                          //belows are optional
                                          type: "text", // "text" or "ssml"
                                          voiceName: "en-US-Standard-B",
                                          languageCode: "en-US",
                                          ssmlGender: "FEMALE",
                                          callback: (error)=> {
                                            console.log(error) // <= What you need.
                                          Rags @Rags
                                          @Rags said in MMM-OpenAI:
                                          @MMRIZE @MMRIZE
                                          So once again some issue has cropped up. The Openai integration with Telegrambot was working fine up to now. However, now the /chatai messages are not getting displayed on the MM whereas they are getting displayed on the Telegrambot app on the phone. The /txtai and /imgai have no issues. Please help in getting it to work again.
                                          R M 2 Replies Last reply Reply Quote 0
                                            Rags @Rags
                                            @MMRIZE @MMRIZE
                                            Can the developer please look into the issue described above. Thanks
