    my Netatmo weather module has not been working
    5 Posts 3 Posters 2.4k Views 3 Watching
      sil3ntstorm
      Hello everyone, my Netatmo weather module has not been working for about 2 weeks. MM and module are updated, meanwhile I have the feeling that netatmo has changed something in their api.
      Does anyone else have the same problem?
      I use this module:
      https://github.com/RaymondMolenaar/MMM-Netatmo
      Danke Google für die Übersetzung :-)
      FoziF 1 Reply Last reply Reply Quote 0
      • FoziF
        Fozi Project Sponsor @sil3ntstorm
        @sil3ntstorm Yeah, Netatmo have changed the refresh token and access token mechanism.
        This is the solution:
        1. Disable or delete your current app with clientID, client secret, refresh token, etc. and create a new app.
        2. There you’ll receive a new clientID and client secret, which you insert in config.js
        3. In the section “Token Generator” you select the scope
        read_station
        and click on “generate token”.
        4. Then you should receive a new access token and refresh token
        5. Enter the new refresh token in config.js
        6. And now the special “trick”: add the attribute accessToken in the module configuration, like that:
        accessToken: "xxxxxxxxxxxxxx|yyyyyyyyyyyyyyyy",
        Netatmo requires now a valid accessToken during authentication.
        Save the config.js and restart the mirror. Everything should work now.
          sil3ntstorm @Fozi
          @Fozi oh dear god, that was the solution. Thank you very much. it works now
          • FoziF
            @sil3ntstorm you’re welcome!
            • C
              cabania @Fozi
              @Fozi MANY THANKS!!!
