    MMM-GoogleCalendar Merging Two Shared Calendars
    8 Posts 3 Posters 1.8k Views 3 Watching
    • J
      jclewis
      Hello,
      I am building MM using MMM-GoogleCalendar. I have main google calendar that has events and I want to integrate my wife’s calendar that has events she populated. In my calendar settings, it is listed under settings for my calendar and I have full control along with her calendarID. I have both calendarIDs listed but when I start the mirror, it shows her calendar. I am looking to have the two calendars merged so it shows the calendar upcoming events merged and sequential instead of just one calendar. Is there a way to add this in the config. I am kinda stuck right now. Also, I am trying not to import her calendar into mine manually. Thoughts? Thanks.
      • BKeyportB
        @sdetweil Oh, gotcha. Yes. No more than one per bracket set.
          sdetweil @jclewis
          @jclewis
          the config is two (or however many u need) url blocks
                  url:"........"
                   url:"......"
          when u have two together in the same block, the last one replaces the first
          BKeyportB 1 Reply Last reply
          • BKeyportB
            @sdetweil Not sure what you were intending to say here, but I believe “replaces” is the wrong word - The calendar app (and all apps that use it, naturally) will merge internally all calendars added within the same calendar block.
            Live example:
            						url: "https://recollect.a.ssl.fastly.net/api/places/BC71002A-F27F-11E8-B5B7-6853A40EAB6C/services/579/events.en-US.ics?client_id=91264B66-7113-11ED-8C28-2101D6C077E5",
            						url: "http://cal.events/VReW45.ics",
            						color: "#69BE28",
            						url: "https://calendar.google.com/calendar/ical/3vejg64nfe9hk5odcphufgis14%40group.calendar.google.com/private-ae3d986ef6488a425755baf7198a1c99/basic.ics",
            						color: "#69BE28",
            						url: "https://calendar.google.com/calendar/ical/mp4efjqgjiq6hphri5ppkkm66k%40group.calendar.google.com/private-81bfdc024de66a7639ac010dfe56263a/basic.ics",
            						color: "#E8291C",
            						url: "https://calendar.google.com/calendar/ical/fgl0a1o8duc3quq3mpjlcopk50%40group.calendar.google.com/private-c55f9de420fe504de01c18f263d70fa7/basic.ics",
            						color: "#69BE28",
            						url: "https://calendar.google.com/calendar/ical/a6fras24hof5ibrk9q1aeg0igg%40group.calendar.google.com/private-147cebc733aab31784e2ab7f18c13cbc/basic.ics",
            						color: "#69BE28",
            						url: "https://gohuskies.com/calendar.ashx/calendar.ics?sport_id=3",
            						color: "#69BE28",
            						url: "webcal://calendar.google.com/calendar/ical/d2dba52c05b47583471f0eccbdb79938b9b0d5ef7711298f4c3455fe64ae6ffa%40group.calendar.google.com/public/basic.ics",
            						color: "#e93b16",
            						url: "https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics",
            						url: "https://calendar.google.com/calendar/ical/futpub9jb1fisumog0u68s9pdc%40group.calendar.google.com/public/basic.ics",
            						color: "#FF1493",
            // Third Calendar
            						url: "https://calendar.google.com/calendar/ical/ufeoastn72l4rcaact44k3iff3pfcun5%40import.calendar.google.com/public/basic.ics",
            (Note: I don’t usually have the calendar app showing, so it’s set up very basic, anything extra that don’t appear to show is because of defaults)
              sdetweil @BKeyport
              @BKeyport if you had
                  url:"....",
                  url:"??????"
              the second would win
              many people don’t see the {} as meaning something, and don’t see the [] around them.
              J BKeyportB 2 Replies Last reply
              • J
                jclewis @sdetweil
                @sdetweil @BKeyport
                I will test this over the weekend. For the url is it the public or private one used? Thanks for the guidance.
                • BKeyportB
                    sdetweil @jclewis
                    @jclewis public or private doesn’t matter
                    J 1 Reply Last reply
                    • J
                      jclewis @sdetweil
                      All,
                      Got it to work. Thank you for the help with this. I appreciate it.
