    MMM-Nest-Status
    3 Posts 3 Posters 948 Views 3 Watching
    • W
      whimsicality
      Has anyone found a way around the fact this app uses an older API system for google? I went through the process of setting it up but it doesn’t work. Just wondering… I wanted to set up cam and nest but looks like it’s not possible until both this one and the other of Michael’s apps are updated
      S R 2 Replies Last reply
        sdetweil @whimsicality
        @whimsicality well last updated a year ago, so maybe open an issue to see if he can help
        • R
          rts58 @whimsicality
          @whimsicality I have the MMM-Nest-Status module working. I set it up a couple months ago. I followed the pretty detailed process he laid out. I remember part of it didn’t seem to work, I had to back out or close something, but was able to get the needed Client ID, Client Secret, Project ID, and Refresh Token. It was confusing enough that I don’t think I could help walk you through, but I can at least confirm that it does work. It worked at the start and then started giving me authentication failed errors. It may have been a wifi issue, they seem to have gone away on their own.
