    MM Windows 10 Install
    11 Posts 2 Posters 2.5k Views 2 Watching
    • C
      Cochise
      An extreme nube here but trying to run MM on a Win 10 stick pc. Run config check returns Line 21 column 2: Parsing error: Unexpected token basePath. Not sure what to try/do next. Config pasted below, thanks in advance for any help here…
      • C
        Cochise @sdetweil
        @sdetweil Spot on, managed to work through all of the bugs (with a great thanks to you Sir) and have a working/functioning MagicMirror running on Win 10…SOLVED!!!
          sdetweil @Cochise
          @Cochise can’t read on my phone
          but unexpected token, 99% of the time is a missing trailing comma on the line before the reported line
          • C
            Cochise @sdetweil
              sdetweil @Cochise
              @Cochise can u show column 1
              • C
                Cochise @sdetweil
                @sdetweil Solved it, reloaded the config file and MM is running but the weather current and forecast will not load
                  sdetweil @Cochise
                  @Cochise open the developers window ctrl-shift-i on the keyboard and select the console tab
                  enter part of the module name in the filter field to see the module browser side messages
                  • C
                    Cochise @sdetweil
                    @sdetweil Failed to load resource: the server responded with a status of 401 (unauthorized)
                    api.openweathermap.org/data/2.5/weather?
                    id=5128581&units =metric&lang=en&APPID=YOUR_OPENWEATHER_API_KEY
                      sdetweil @Cochise
                      @Cochise suppose you should put your apikey in the config
                      • C
                        Cochise @sdetweil
                        @sdetweil Indeed, I had applied the API Key to a sample config file. Like I said, still learning here. Working through everything it is two steps forward and three steps back. Trying to update the proper time zone, lost clock and day/date altogether
                          sdetweil @Cochise
                          @Cochise MagicMirror is case sensitive
                          • C
                            Cochise @sdetweil
