    MMM Google Photos
    3 Posts 2 Posters 580 Views 2 Watching
    • V Offline
      vijayb
      Any thoughts on this error message setting up MMM-Google-Photos. What is the ‘moment’ module ?
      /magicmirror/mounts/modules/MMM-GooglePhotos $ node generate_token
      node:internal/modules/cjs/loader:1080
      throw err;
      Error: Cannot find module ‘moment’
      Require stack:
      • /home/vijay/magicmirror/mounts/modules/MMM-GooglePhotos/GPhotos.js
      • /home/vijay/magicmirror/mounts/modules/MMM-GooglePhotos/generate_token.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Module.require (node:internal/modules/cjs/loader:1143:19)
        at require (node:internal/modules/cjs/helpers:110:18)
        at Object. (/home/vijay/magicmirror/mounts/modules/MMM-GooglePhotos/GPhotos.js:12:16)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1310:10)
        at Module.load (node:internal/modules/cjs/loader:1119:32)
        at Module._load (node:internal/modules/cjs/loader:960:12)
        at Module.require (node:internal/modules/cjs/loader:1143:19) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        ‘/home/vijay/magicmirror/mounts/modules/MMM-GooglePhotos/GPhotos.js’,
        ‘/home/vijay/magicmirror/mounts/modules/MMM-GooglePhotos/generate_token.js’
      Node.js v18.16.1
      • V Offline
        vijayb
        Thanks!
        Something about the folder from where I issued the command. I think I was doing it from the wrong. Got it to work! Thank @sdetweil
          sdetweil @vijayb
          @vijayb sounds like you didn’t do the npm install in the module folder after git clone
          • V Offline
            vijayb
            Thanks!
