    MMM-RandomQuranAyah
    Scheduled Pinned Locked Moved Education
    34 Posts 7 Posters 23.4k Views 7 Watching
    • slametpsS Offline
      slametps @Gxnfr Ali
      @Gxnfr-Ali said in MMM-RandomQuranAyah:
      @slametps i want add prayer module in our project…magicmirror
      What I ment earlier is disable all modules config except PrayerTime config to start debugging what made wrong if you’re sure that Prayer Time is the cause for your MM error. That is the only way to locate the error.
      regards,
      Slamet PS
      • H Offline
        hrjmsh
        Hi Slamet
        I am having the following error on start up
        Error: Cannot find module ‘async’
        This makes the magic mirror go blank and disables keyboard commands. I disabled all other modules and corrected syntax errors in PrayerTime config lines as you described in previous posts.
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS Offline
          slametps @hrjmsh
          @hrjmsh :
          try install nodejs async module first:
          npm install --save async
          regards,
          Slamet PS
          • H Offline
            hrjmsh
            Working great. Jazak Allah. You are a star!
            • 4 / 4
