    MMM-RandomQuranAyah
    Scheduled Pinned Locked Moved Education
    34 Posts 7 Posters 26.5k Views 7 Watching
    • Z Offline
      zzaidi148 @slametps
      @slametps I took the character off but still something wrong
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      		module: 'MMM-RandomQuranAyah',
      		position: 'top_bar',
      			apiVersion: '1.0'
      			showArabic: true,
      			showTranslation: true,
      			surahArabicName:false,
      			translationLang:'id.indonesian',
      			updateInterval: 3600 * 1000,
      			module: "alert",
      			module: "clock",
      			header: "US Holidays",
      					symbol: "calendar-check-o",
      					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
      			module: "compliments",
      			position: "lower_third",
      			module: "currentweather",
      				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "private",
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      						title: "ESPN",
      						url: "http://www.espnfc.com/english-premier-league/23/rss"
      				showSourceTitle: true,
      				showPublishDate: true
                  	        module: 'MMM-GoogleMapsTraffic',
      			position: 'top_left',
                      	   key: '',
                      	   lat: 33.033184,
                      	   lng: -96.625225,
                      	   height: '350px',
                      	   width: '400px',
      slametpsS 1 Reply Last reply Reply Quote 0
      • slametpsS Offline
        slametps @zzaidi148
        @zzaidi148 said in MMM-RandomQuranAyah:
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 12,
        	units: "imperial",
        			apiVersion: '1.0'
        			showArabic: true,
        			module: "alert",
        			module: "clock",
        				appid: "private",
        				appid: "",
        			module: "newsfeed",
        				feeds: [
        						title: "ESPN",
                        	   key: '',
                        	   lat: 33.033184,
                        	   lng: -96.625225,
                        	   height: '350px',
                        	   width: '400px',
        There is missing character comma (,) after apiVersion: '1.0'.
        regards,
        Slamet PS
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          zzaidi148 @slametps
          @slametps Alhumdulillah, actually worked! Is there any way to change the translation beside en.yusufali in english. Also, my arabic font is different from your screenshot. How do I get your arabic font? Thank you so much!
          • slametpsS Offline
            slametps @zzaidi148
            Complete translation option can be found at http://api.alquran.cloud/edition. My shot is a browser capture, not actual MM capture and the font is indeed different.
            Actual result is like this:
            https://www.instagram.com/p/BR43DnDgG_r/.
            regards,
            Slamet PS
            Z G 3 Replies Last reply Reply Quote 0
            • Z Offline
              zzaidi148 @slametps
              @slametps Thank You
              • G Offline
                Gxnfr Ali @slametps
                @slametps that is my confis.js file…but prayer module does not work…cn u tell me error in config.js file???
                • By Michael Teeuw http://michaelteeuw.nl
                • MIT Licensed.
                var config = {
                port: 8080,
                ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
                language: "en",
                timeFormat: 24,
                units: "metric",
                		module: "alert",
                		module: "updatenotification",
                		position: "top_bar"
                	module: 'email',
                            position: 'bottom_left',
                            header: 'Email',
                                accounts: [
                                        user: 'xxxxx@gmail.com',
                                        password: 'xxxxx',
                                        host: 'imap.gmail.com',
                                        port: 993,
                                        tls: true,
                                        authTimeout: 10000,
                                        numberOfEmails: 2,
                                fade: true,
                                maxCharacters: 30
                		module: "clock",
                		position: "top_left"
                		header: "PK Holidays",
                					symbol: "calendar-check-o ",
                					url: "webcal://www.officeholidays.com/ics/ics_country_code.php?iso=PK"
                			locationID: "1166547",  //ID from http://www.openweathermap.org/help/city_list.txt
                			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
                			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                		module: 'MMM-PrayerTime',
                			apiVersion: '1.0',
                			lat: '30.6612',
                			lon: '73.1086',
                			timezone: 'Asia/Karachi',
                			method: 4,
                			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                			notDisplayed: ['midnight', 'sunset'],
                			useUpdateInterval: true,
                			updateInterval: 86400 * 1000,
                			animationSpeed: 2.5 * 1000,
                			language: config.language,
                			showAdzanAlert: true,
                			alertTimer: 15000
                		module: "newsfeed",
                			feeds: [
                					title: "Pakistan News",
                					url: "https://news.google.com/news/rss/local?ned=en_pk&hl=en&gl=US"
                if (typeof module !== “undefined”) {module.exports = config;}
                • G Offline
                  Gxnfr Ali @slametps
                  @slametps
                  WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                  during prayer time module
                  • slametpsS Offline
                    slametps @Gxnfr Ali
                    @Gxnfr-Ali said in MMM-RandomQuranAyah:
                    @slametps
                    You can remove config item “language: config.language”. The module, by default using that config. It not working, you should try removing all modules config but PrayerTime.
                    regards,
                    Slamet PS
                    • G Offline
                      Gxnfr Ali @slametps
                      @slametps
                      hi
                      • G Offline
                        Gxnfr Ali @slametps
                        @slametps i want add prayer module in our project…magicmirror
                        • slametpsS Offline
                          slametps @Gxnfr Ali
                          What I ment earlier is disable all modules config except PrayerTime config to start debugging what made wrong if you’re sure that Prayer Time is the cause for your MM error. That is the only way to locate the error.
                          regards,
                          Slamet PS
                          • H Offline
                            hrjmsh
                            Hi Slamet
                            I am having the following error on start up
                            Error: Cannot find module ‘async’
                            This makes the magic mirror go blank and disables keyboard commands. I disabled all other modules and corrected syntax errors in PrayerTime config lines as you described in previous posts.
                            • slametpsS Offline
                              slametps @hrjmsh
                              @hrjmsh :
                              try install nodejs async module first:
                              npm install --save async
                              regards,
                              Slamet PS
                              • H Offline
                                hrjmsh
                                Working great. Jazak Allah. You are a star!
