    MMM-RandomQuranAyah
    Scheduled Pinned Locked Moved Education
    34 Posts 7 Posters 26.6k Views 7 Watching
    • slametpsS Offline
      slametps @slametps
      @slametps said in MMM-RandomQuranAyah:
      @zzaidi148 said in MMM-RandomQuranAyah:
      @slametps it just said to recheck your config
      Can you post your whole config? It seems your config is the problem.
      There is character / after config ApiVersion. Pls remove it.
      regards,
      Slamet PS
      Z 1 Reply Last reply Reply Quote 0
      • Z Offline
        zzaidi148 @slametps
        @slametps I took the character off but still something wrong
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 12,
        	units: "imperial",
        		module: 'MMM-RandomQuranAyah',
        		position: 'top_bar',
        			apiVersion: '1.0'
        			showArabic: true,
        			showTranslation: true,
        			surahArabicName:false,
        			translationLang:'id.indonesian',
        			updateInterval: 3600 * 1000,
        			module: "alert",
        			module: "clock",
        			header: "US Holidays",
        					symbol: "calendar-check-o",
        					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
        			module: "compliments",
        			position: "lower_third",
        			module: "currentweather",
        				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
        				appid: "private",
        			module: "weatherforecast",
        			header: "Weather Forecast",
        				appid: "",
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
        						title: "ESPN",
        						url: "http://www.espnfc.com/english-premier-league/23/rss"
        				showSourceTitle: true,
        				showPublishDate: true
                    	        module: 'MMM-GoogleMapsTraffic',
        			position: 'top_left',
                        	   key: '',
                        	   lat: 33.033184,
                        	   lng: -96.625225,
                        	   height: '350px',
                        	   width: '400px',
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS Offline
          slametps @zzaidi148
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 12,
          	units: "imperial",
          			apiVersion: '1.0'
          			showArabic: true,
          			module: "alert",
          			module: "clock",
          				appid: "private",
          				appid: "",
          			module: "newsfeed",
          				feeds: [
          						title: "ESPN",
                          	   key: '',
                          	   lat: 33.033184,
                          	   lng: -96.625225,
                          	   height: '350px',
                          	   width: '400px',
          There is missing character comma (,) after apiVersion: '1.0'.
          regards,
          Slamet PS
          • Z Offline
            zzaidi148 @slametps
            @slametps Alhumdulillah, actually worked! Is there any way to change the translation beside en.yusufali in english. Also, my arabic font is different from your screenshot. How do I get your arabic font? Thank you so much!
            • slametpsS Offline
              slametps @zzaidi148
              Complete translation option can be found at http://api.alquran.cloud/edition. My shot is a browser capture, not actual MM capture and the font is indeed different.
              Actual result is like this:
              https://www.instagram.com/p/BR43DnDgG_r/.
              regards,
              Slamet PS
              Z G 3 Replies Last reply Reply Quote 0
              • Z Offline
                zzaidi148 @slametps
                @slametps Thank You
                • G Offline
                  Gxnfr Ali @slametps
                  @slametps that is my confis.js file…but prayer module does not work…cn u tell me error in config.js file???
                  • MIT Licensed.
                  var config = {
                  port: 8080,
                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
                  language: "en",
                  timeFormat: 24,
                  units: "metric",
                  		module: "alert",
                  		module: "updatenotification",
                  		position: "top_bar"
                  	module: 'email',
                              position: 'bottom_left',
                              header: 'Email',
                                  accounts: [
                                          user: 'xxxxx@gmail.com',
                                          password: 'xxxxx',
                                          host: 'imap.gmail.com',
                                          port: 993,
                                          tls: true,
                                          authTimeout: 10000,
                                          numberOfEmails: 2,
                                  fade: true,
                                  maxCharacters: 30
                  		module: "clock",
                  		position: "top_left"
                  		header: "PK Holidays",
                  					symbol: "calendar-check-o ",
                  					url: "webcal://www.officeholidays.com/ics/ics_country_code.php?iso=PK"
                  			locationID: "1166547",  //ID from http://www.openweathermap.org/help/city_list.txt
                  			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
                  			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                  		module: 'MMM-PrayerTime',
                  			apiVersion: '1.0',
                  			lat: '30.6612',
                  			lon: '73.1086',
                  			timezone: 'Asia/Karachi',
                  			method: 4,
                  			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                  			notDisplayed: ['midnight', 'sunset'],
                  			useUpdateInterval: true,
                  			updateInterval: 86400 * 1000,
                  			animationSpeed: 2.5 * 1000,
                  			language: config.language,
                  			showAdzanAlert: true,
                  			alertTimer: 15000
                  		module: "newsfeed",
                  			feeds: [
                  					title: "Pakistan News",
                  					url: "https://news.google.com/news/rss/local?ned=en_pk&hl=en&gl=US"
                  if (typeof module !== “undefined”) {module.exports = config;}
                  • G Offline
                    Gxnfr Ali @slametps
                    @slametps
                    WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                    during prayer time module
                    • slametpsS Offline
                      slametps @Gxnfr Ali
                      @Gxnfr-Ali said in MMM-RandomQuranAyah:
                      @slametps
                      You can remove config item “language: config.language”. The module, by default using that config. It not working, you should try removing all modules config but PrayerTime.
                      regards,
                      Slamet PS
                      • G Offline
                        Gxnfr Ali @slametps
                        @slametps
                        hi
                        • G Offline
                          Gxnfr Ali @slametps
                          @slametps i want add prayer module in our project…magicmirror
                          • slametpsS Offline
                            slametps @Gxnfr Ali
                            What I ment earlier is disable all modules config except PrayerTime config to start debugging what made wrong if you’re sure that Prayer Time is the cause for your MM error. That is the only way to locate the error.
                            regards,
                            Slamet PS
                            • H Offline
                              hrjmsh
                              Hi Slamet
                              I am having the following error on start up
                              Error: Cannot find module ‘async’
                              This makes the magic mirror go blank and disables keyboard commands. I disabled all other modules and corrected syntax errors in PrayerTime config lines as you described in previous posts.
                              • slametpsS Offline
                                slametps @hrjmsh
                                @hrjmsh :
                                try install nodejs async module first:
                                npm install --save async
                                regards,
                                Slamet PS
                                • H Offline
                                  hrjmsh
                                  Working great. Jazak Allah. You are a star!
