    MMM-RandomQuranAyah
    Scheduled Pinned Locked Moved Education
    34 Posts 7 Posters 25.0k Views 7 Watching
    • Z Offline
      zzaidi148 @slametps
      @slametps Thank You
      • G Offline
        Gxnfr Ali @slametps
        @slametps that is my confis.js file…but prayer module does not work…cn u tell me error in config.js file???
        /* Magic Mirror Config Sample
        • MIT Licensed.
        var config = {
        port: 8080,
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
        language: "en",
        timeFormat: 24,
        units: "metric",
        		module: "alert",
        		module: "updatenotification",
        		position: "top_bar"
        	module: 'email',
                    position: 'bottom_left',
                    header: 'Email',
                        accounts: [
                                user: 'xxxxx@gmail.com',
                                password: 'xxxxx',
                                host: 'imap.gmail.com',
                                port: 993,
                                tls: true,
                                authTimeout: 10000,
                                numberOfEmails: 2,
                        fade: true,
                        maxCharacters: 30
        		module: "clock",
        		position: "top_left"
        		header: "PK Holidays",
        					symbol: "calendar-check-o ",
        					url: "webcal://www.officeholidays.com/ics/ics_country_code.php?iso=PK"
        		module: "compliments",
        		position: "lower_third"
        		module: "currentweather",
        			locationID: "1166547",  //ID from http://www.openweathermap.org/help/city_list.txt
        			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
        		module: "weatherforecast",
        		header: "Weather Forecast",
        			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
        		module: 'MMM-PrayerTime',
        		position: 'top_left',
        			apiVersion: '1.0',
        			lat: '30.6612',
        			lon: '73.1086',
        			timezone: 'Asia/Karachi',
        			method: 4,
        			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
        			notDisplayed: ['midnight', 'sunset'],
        			useUpdateInterval: true,
        			updateInterval: 86400 * 1000,
        			animationSpeed: 2.5 * 1000,
        			language: config.language,
        			showAdzanAlert: true,
        			alertTimer: 15000
        		module: "newsfeed",
        		position: "bottom_bar",
        			feeds: [
        					title: "Pakistan News",
        					url: "https://news.google.com/news/rss/local?ned=en_pk&hl=en&gl=US"
        			showSourceTitle: true,
        			showPublishDate: true
        if (typeof module !== “undefined”) {module.exports = config;}
        • G Offline
          Gxnfr Ali @slametps
          @slametps
          WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
          during prayer time module
          slametpsS 1 Reply Last reply Reply Quote 0
          • slametpsS Offline
            slametps @Gxnfr Ali
            @Gxnfr-Ali said in MMM-RandomQuranAyah:
            @slametps
            You can remove config item “language: config.language”. The module, by default using that config. It not working, you should try removing all modules config but PrayerTime.
            regards,
            Slamet PS
            • G Offline
              Gxnfr Ali @slametps
              @slametps
              hi
              • G Offline
                Gxnfr Ali @slametps
                @slametps i want add prayer module in our project…magicmirror
                • slametpsS Offline
                  slametps @Gxnfr Ali
                  What I ment earlier is disable all modules config except PrayerTime config to start debugging what made wrong if you’re sure that Prayer Time is the cause for your MM error. That is the only way to locate the error.
                  regards,
                  Slamet PS
                  • H Offline
                    hrjmsh
                    Hi Slamet
                    I am having the following error on start up
                    Error: Cannot find module ‘async’
                    This makes the magic mirror go blank and disables keyboard commands. I disabled all other modules and corrected syntax errors in PrayerTime config lines as you described in previous posts.
                    • slametpsS Offline
                      slametps @hrjmsh
                      @hrjmsh :
                      try install nodejs async module first:
                      npm install --save async
                      regards,
                      Slamet PS
                      • H Offline
                        hrjmsh
                        Working great. Jazak Allah. You are a star!
