    MMM-RandomQuranAyah
    Scheduled Pinned Locked Moved Education
    34 Posts 7 Posters 23.1k Views 7 Watching
    • Z Offline
      zzaidi148 @slametps
      @slametps I took the character off but still something wrong
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      		module: 'MMM-RandomQuranAyah',
      		position: 'top_bar',
      			apiVersion: '1.0'
      			showArabic: true,
      			showTranslation: true,
      			surahArabicName:false,
      			translationLang:'id.indonesian',
      			updateInterval: 3600 * 1000,
      			module: "alert",
      			module: "clock",
      			header: "US Holidays",
      					symbol: "calendar-check-o",
      					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
      			module: "compliments",
      			position: "lower_third",
      			module: "currentweather",
      				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "private",
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      						title: "ESPN",
      						url: "http://www.espnfc.com/english-premier-league/23/rss"
      				showSourceTitle: true,
      				showPublishDate: true
                  	        module: 'MMM-GoogleMapsTraffic',
      			position: 'top_left',
                      	   key: '',
                      	   lat: 33.033184,
                      	   lng: -96.625225,
                      	   height: '350px',
                      	   width: '400px',
      slametpsS 1 Reply Last reply Reply Quote 0
      • slametpsS Offline
        slametps @zzaidi148
        @zzaidi148 said in MMM-RandomQuranAyah:
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 12,
        	units: "imperial",
        			apiVersion: '1.0'
        			showArabic: true,
        			module: "alert",
        			module: "clock",
        				appid: "private",
        				appid: "",
        			module: "newsfeed",
        				feeds: [
        						title: "ESPN",
                        	   key: '',
                        	   lat: 33.033184,
                        	   lng: -96.625225,
                        	   height: '350px',
                        	   width: '400px',
        There is missing character comma (,) after apiVersion: '1.0'.
        regards,
        Slamet PS
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          zzaidi148 @slametps
          @slametps Alhumdulillah, actually worked! Is there any way to change the translation beside en.yusufali in english. Also, my arabic font is different from your screenshot. How do I get your arabic font? Thank you so much!
          • slametpsS Offline
            slametps @zzaidi148
            Complete translation option can be found at http://api.alquran.cloud/edition. My shot is a browser capture, not actual MM capture and the font is indeed different.
            Actual result is like this:
            https://www.instagram.com/p/BR43DnDgG_r/.
            regards,
            Slamet PS
            Z G 3 Replies Last reply Reply Quote 0
            • Z Offline
              zzaidi148 @slametps
              @slametps Thank You
              • G Offline
                Gxnfr Ali @slametps
                @slametps that is my confis.js file…but prayer module does not work…cn u tell me error in config.js file???
                • By Michael Teeuw http://michaelteeuw.nl
                • MIT Licensed.
                var config = {
                port: 8080,
                ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
                language: "en",
                timeFormat: 24,
                units: "metric",
                		module: "alert",
                		module: "updatenotification",
                		position: "top_bar"
                	module: 'email',
                            position: 'bottom_left',
                            header: 'Email',
                                accounts: [
                                        user: 'xxxxx@gmail.com',
                                        password: 'xxxxx',
                                        host: 'imap.gmail.com',
                                        port: 993,
                                        tls: true,
                                        authTimeout: 10000,
                                        numberOfEmails: 2,
                                fade: true,
                                maxCharacters: 30
                		module: "clock",
                		position: "top_left"
                		header: "PK Holidays",
                					symbol: "calendar-check-o ",
                					url: "webcal://www.officeholidays.com/ics/ics_country_code.php?iso=PK"
                			locationID: "1166547",  //ID from http://www.openweathermap.org/help/city_list.txt
                			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
                			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                		module: 'MMM-PrayerTime',
                			apiVersion: '1.0',
                			lat: '30.6612',
                			lon: '73.1086',
                			timezone: 'Asia/Karachi',
                			method: 4,
                			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                			notDisplayed: ['midnight', 'sunset'],
                			useUpdateInterval: true,
                			updateInterval: 86400 * 1000,
                			animationSpeed: 2.5 * 1000,
                			language: config.language,
                			showAdzanAlert: true,
                			alertTimer: 15000
                		module: "newsfeed",
                			feeds: [
                					title: "Pakistan News",
                					url: "https://news.google.com/news/rss/local?ned=en_pk&hl=en&gl=US"
                if (typeof module !== “undefined”) {module.exports = config;}
                • G Offline
                  Gxnfr Ali @slametps
                  @slametps
                  WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                  during prayer time module
                  • slametpsS Offline
                    slametps @Gxnfr Ali
                    @Gxnfr-Ali said in MMM-RandomQuranAyah:
                    @slametps
                    You can remove config item “language: config.language”. The module, by default using that config. It not working, you should try removing all modules config but PrayerTime.
                    regards,
                    Slamet PS
                    • G Offline
                      Gxnfr Ali @slametps
                      @slametps
                      hi
                      • G Offline
                        Gxnfr Ali @slametps
                        @slametps i want add prayer module in our project…magicmirror
                        • 3 / 4
