    Alexa control
    6 Posts 2 Posters 1.6k Views 2 Watching
    • V
      videogame95
      Re: Alexa echo dot
      Hi I add the code from Alexa controlled to my configuration file .js
      And it stopped it working I didn’t change anything except add a , on the of the},
      When I removed the script it worked ? What am doing wrong I past in wrong do ?I need add all code in module for it to work ? Or just first js and just the second js file or could it be the way its pasted in to js. Config . I always line up the first brake and larst bracket with overhead brackets ? And add , to last }, like this .
      Thanks for any help
        sdetweil @videogame95
        @videogame95 sorry, do not understand your post…
        all the modules install the same
        cd ~/MagicMirror/modules
        git clone  /// url ///
        cd Modulename
            if package.json exists, npm install
        cd ~/MagicMirror/config
         nano config.js (or use your other favorite editor)
        copy the config example for the module
        paste as new module before end of module list
        module example goes here
        end of list
        end of config data
        if //
        some examples include too much , this one does add too much
        modules:[   // DO NOT ADD THIS LINE, it is already present
                module: 'MMM-AlexaControl',
                position: 'middle_center',
                config:{
                    image: true,
                    pm2ProcessName: "mm",
                    vcgencmd: "vcgencmd"
        ]  // DO NOT ADD THIS LINE, it is already present
        V 2 Replies Last reply Reply Quote 0
        • V
          videogame95 @sdetweil
          @sdetweil I
          Thanks your great
          I had to do this with one of other modules
          It’s not always staight forward
          I’ll give it ago once again thanks
          New subject my EXT-pages works fine on the timed rotation
          If add recipes in GoogleAssistant [“test.js]”,
          This from my GoogleAssistant recipes folder
          Recipes
          My configuration
          I’ll put up later as not on my pi
          What happens in sort of works I say go to page 2
          It go to page 2
          But when say go to page 3 in freezes up no voice controll on mouse control is totally,
          Lock up.
          Any help with my recipes with 3 page on magicmirror2
          • V
            I tried to reply to but couldn’t find the post I removed the parts you said to remove
            The configuration come no driver sewt something like that and doesn’t run.
            I try up load my configuration.
              @videogame95 sorry, I do not understand your words
              • V
                Hi when run magicmirror npm start
                With the Alexa control in my configuration file
                In the Terminal in say load up like drive sewt something like .
                And magicmirror 2 freeze up and will no run .
                I had removed the module
                And larst bracket [
                As instructions you sent me
                Any help getting my Alexa control to work?
                Or we try get GoogleAssistant to change my pages
                My EXT PAGES: is working in timed CAROUSEL is working
                My GoogleAssistant recipes folder
                With pages changing code has problem .
                It starts up fine
                If I ask it to . go to page 2 it works.
                But if ask it to go to page 3 it all freezes up totally locked I have do hard reboot.
                Any help in this problem?
                Thanks James videogame95
