    Alexa echo dot 5th gen
    4 Posts 2 Posters 832 Views 2 Watching
    • V Offline
      videogame95
      Re: Alexa echo dot
      Where do lock the install code is it in magicmirror modules and any on configure it
      I look in module if I get stuck I’ll get back to you thanks from James
        sdetweil @videogame95
        @videogame95 I do not understand your words. maybe use translater
        • V Offline
          videogame95
          Where can get the install code for Alexa echo dot or Alexa control?
            @videogame95 same as every other module. github. easy search
            github mmm-alexacontrol
