    Acoustic panel frame with mirror effect
    10 Posts 5 Posters 5.7k Views 8 Watching
      BravoOscar
      Hi all!
      I just finish our magic mirror with information for the family.
      The magic mirror runs on an RPI4 4GB and an 19" laptop old screen. The mirror glas is 33cm x 54,5cm and 4mm thick. I also added a pir-sensor to activate the magic mirror and a on/off buttom to turn everythink off.
      Used modules:
      MMM-PIR-Sensor-Litel Turn on the screen for 1 min
      MMM-WiFiPassword Only shows QR code
      MMM-MyWastePickup Changed to fit all type of wastebin in Denmark with correct pictures
      MMM-Jast Displays stocks
      MMM-CalendarExt3 Display one family calender
      MMM-Traffic Displays time to work and vacationshouse
      MMM-OpenWeatherForecast Display local weather
      MMM-RTSPStream Display one live security cam from our house
      Default Clock module
      What have I used:
      Acoustic panel Frame I cut it to have 20cm over and under the screen
      Glass mirror film Just followed the video on Youtube how to apply the mirror film
      Glass holders
      On/off buttom installed top right corner on the backside of the mirror
      Pir-Sensor installed center bottom backside of the mirror
      Raspberry Pi
      I have installed VNC, so I cant remote connect to the Mirror and update everythink.
      I use sdetweil script to update Magic Mirror.
      This is the final look:
      RaspiManuR htilburgsH A 3 Replies Last reply Reply Quote 7
      • RaspiManuR Offline
        RaspiManu @BravoOscar
        @BravoOscar
        Very interesting frame. Looks great and can easily be combined with some more acoustic panels. Glad you shared it 😊
        • htilburgsH Offline
          htilburgs @BravoOscar
          @BravoOscar
          How did you go around the edge?
          (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
            BravoOscar @htilburgs
            @htilburgs
            I just a knife like this.
            Then make a cut approx ½ deep in the filt, then you can bend it arround and screw it to the frame from the backside.
            htilburgsH 1 Reply Last reply Reply Quote 0
              @BravoOscar thanks. 😊
                ashna @BravoOscar
                @BravoOscar I absolutely love this!! Did you create a new socket location?
                T B 2 Replies Last reply Reply Quote 0
                • T Offline
                  tuansacto @ashna
                  @BravoOscar Looks great I really like it. I’m curious about the mirror. You use the glass mirror (33x54x4mm) then apply the glass film on top. Can you specifically describe the glass mirror? I’d like to build one like yours. A 2-way mirror is so expensive. So it’s a regular mirror with back coating? Transparent mirror or what? Thank you very much!
                  B htilburgsH 2 Replies Last reply Reply Quote 0
                    BravoOscar @ashna
                    @ashna I installed a new socket behind the Mirror when I renovated the wall.
                    So yes there is a build in socket behind the Mirror.
                      BravoOscar @tuansacto
                      @tuansacto
                      The glass is just normal glass from the local glass company, I asked if they had som leftovers, They made it for around 6,5 euro (50 dkk)
                      Glass mirror film is from a shop in Denmark (Bauhaus), but it can probably be bought everywhere
                        htilburgs @tuansacto
                        @tuansacto
                        Take a look at https://www.brigla-shop.de/mm-genau/mirropane-chrome-spy-6-mm/smart-mirror-spiegel-260?c=6
                        I just ordered a new mirror 42x72 for under €100 including transport to holland.
