    install/upgrade 2.25 on raspian buster broken
    5 Posts 2 Posters 941 Views 2 Watching
      sdetweil
      I have added a check in my scripts to prevent install/upgrade of 2.25 on buster until we have a workable fix…
      lets not destroy working systems
      • mumblebajM
        mumblebaj Module Developer @sdetweil
        @sdetweil stupid question, how do I install a previous version?
          sdetweil @mumblebaj
          @mumblebaj at the moment only manually… using the tag …
          hang on I may have a way to recover your system… testing now…
          is this a buster system, or bullseye?
          lsb_release -a
          will show the answer
          • mumblebajM
            @sdetweil It is buster. I had to remove the wsl as it got corrupted and refused to do anything. Even running node -v came back with that primordial error.
              sdetweil @mumblebaj
              @mumblebaj yes, the script will fix that
              try the upgrade script again, with force instead of apply
              it will remove and and add the right version of node the right way, including on buster
              please advise your results
