    Failed to export buffer to dma_buf: No such file or directory
    8 Posts 2 Posters 5.7k Views 3 Watching
    • R
      Roncham
      Pi 4 4gb - Bookworm
      New version of MM installed manually, but I can’t run it.
      I tried via the script (update and new), but I got the ‘primordials’ error every time I ran npm.
      xxxx@raspberrypi:~/MagicMirror $ node -v
      v20.8.0
      xxxx@raspberrypi:~/MagicMirror $ npm -v
      10.1.0
      Use `electron --trace-warnings ...` to show where the warning was created)
      [12.10.2023 00:59.31.012] [ERROR] (node:1471) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      [1499:1012/005932.242398:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.242919:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.243488:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.243878:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.244276:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.244665:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.245064:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.247179:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.247513:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.247978:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.248374:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.248791:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.249180:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [1499:1012/005932.249578:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      Thanks in advance,
      Ron
        sdetweil @Roncham
        @Roncham can you do
        uname -a
        and
        file /bin/bash
        if you start over , reinstall the OS image on your SD card
        and then run the script from the testit branch
        it should work on bookworm. I just fixed the script for the 32 bit version on pi4.
        • R
          Roncham @sdetweil
          @sdetweil said in Failed to export buffer to dma_buf: No such file or directory:
          uname -a
          When I tried your script it said I had Node 18…, but node -v shows 20 before I started. Then it dies after installing npm with the ‘primordials’ error.
          Can I purge the node cache without removing node? If so how?
          @raspberrypi:~ $ uname -a
          Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
          @raspberrypi:~ $ file /bin/bash
          /bin/bash: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, BuildID[sha1]=12abba9f431c0bef9f0a2a47f29cc9175159347f, for GNU/Linux 3.2.0, stripped
            sdetweil @Roncham
            @Roncham send me the ~/install.log
            same userid at gmail
            • R
              Roncham @sdetweil
              I started over from scratch. Sorry to waste your time. Your script worked great.
              Thanks!
                sdetweil @Roncham
                @Roncham thanks for the feedback. which is image did you choose? 32 or 64 bit
                • R
                  Roncham @sdetweil
                  @sdetweil 64 bit desktop
                    sdetweil @Roncham
                    @Roncham weird. try this
                    pm2 stop all
                    cd ~/MagicMirror
                    export ELECTRON_DISABLE_GPU=1
                    npm start
                    wait and see if the errors occurs
                    if not
                    add the export line to the script that starts mm
                    in front of the npm start
                    if you used my install script, that is
                    ~/MagicMirror/installers/mm.sh
                    • M MMRIZE referenced this topic on
