    Default Clock wrong after update
    26 Posts 4 Posters 11.0k Views 4 Watching
    • D
      drstang
      Hi ,
      After the newest MM update, the clock module is displaying UTC time, despite my RPi config set to EST.
      Interestingly, when I head to my MMs IP address from a separate computer, the clock is correct.
      Any ideas? Thanks!
      • BKeyportB
        BKeyport Module Developer @drstang
        @drstang does setting the timezone config option adjust it ?
        https://docs.magicmirror.builders/modules/clock.html#configuration-options
        D 1 Reply Last reply
          sdetweil @drstang
          @drstang another user had a similar problem with the calendar…
          rebuilt with a different pi and the problem went away…
          lets try this
          pm2 stop all  (or stop MM if you didn't use pm2)
          cd ~
          rm -rf .config/Electron
          pm2 start all
          • D
            drstang @sdetweil
            @sdetweil Thanks for the reply. Unfortunately - no luck. Still displaying UTC instead of EST.
              sdetweil @drstang
              @drstang thx… and you are certain the SYSTEM timezone is set to EST
              i can’t upload a pic of the config page on the pi… weird
              • D
                drstang @sdetweil
                @sdetweil Yep - did it several times to make sure!
                And the Mirror will show EST when I access it via a web browser!
                BKeyportB 1 Reply Last reply
                • BKeyportB
                  • D
                    drstang @BKeyport
                    @BKeyport thanks but unfortunately that does not work either - it results in the clock module not even loading (unless there was something else I should have adjusted)…
                    EDIT: I realized I changed the modules config initially, which didn’t work. But I changed the main config (duh - reading is key) and added the config/timezone line, which worked!! thank you!
                    BKeyportB S 2 Replies Last reply
                    • BKeyportB
                      @drstang At least you can override it for now…
                      • R
                        Richard238
                        Just updated my MM, clock is showing 18:13 when it’s 11:54…
                          sdetweil @drstang
                          @drstang I don’t understand this, the code does
                          		if (this.config.timezone) {
                          			now.tz(this.config.timezone);
                          which means it only uses its own config values, not the global config.
                          when I set it like this
                          			module: "clock",
                          			config:{
                          				displaySeconds:false,
                          				timezone:"UTC"
                          it correctly changed the displayed time from 08 (us central time) to 13
                          if I set it like this
                          	timeFormat: 24,
                          	units: "metric",
                          	timezone:"UTC",
                          it did not change the displayed time (as expected)
                          • BKeyportB
                            @sdetweil Correction to your statement. timezone is set to null by default. timezone: null, - therefore, that if line would evaluate to false unless you override with timezone config item.
                              sdetweil @BKeyport
                              @BKeyport correct,
                              so a ‘forced’ timezone would not be set
                              this is the same code as before.
                              • BKeyportB
                                @sdetweil said in Default Clock wrong after update:
                                This is what I was correcting. ;)
                                  sdetweil @BKeyport
                                  @BKeyport but he said,
                                  changing it in the module config did NOT work
                                  but
                                  changing it in the GENERAL config DID work…
                                  and it was NOT set in the original config he was using prior to the upgrade
                                  D 2 Replies Last reply
                                    sdetweil @BKeyport
                                    @BKeyport said in Default Clock wrong after update:
                                    I don’t understand…
                                    what I said was
                                    this module only adjusts the timezone when
                                        config :{
                                            timezone: '??????',
                                    in its module definition
                                    NOT when its set in the global configuration, (before modules defined)
                                    timeFormat: 24,
                                    	units: "metric",
                                    	timezone:"UTC",  <---  added this for testing, value NOT set in module config
                                    so I don’t see what you are ‘correcting’
                                    • D
                                      drstang @sdetweil
                                      @sdetweil thats correct - when I changed timezone from ‘null’ to ‘America/New_York,’ the module did not work at all. When I went into the MM config.js and added the timezone line, it worked.
                                      Which now I realize is also a bit frustrating because one of my modules also shows sunrise/sunset times, and thats still off (EST + 4 hrs).
                                      • D
                                        drstang @sdetweil
                                        @sdetweil and also, yes. prior to the upgrade, my general config was NOT set to a TZ prior to the upgrade. I
                                          sdetweil @drstang
                                          @drstang said in Default Clock wrong after update:
                                          correct… as there is no general timezone property
                                          • D
                                            drstang @sdetweil
                                            @sdetweil and what also confuses me is if I access the mirror via a web browser, the times are right!
                                              sdetweil @drstang
                                              @drstang I understand and agree with that…
                                              the clock code runs in the browser… so one can only assume that the
                                              moment code running in the browser is different between instances…
                                              Reply Quote 1
