    Default Clock wrong after update
    26 Posts 4 Posters 8.8k Views 4 Watching
      drstang
      Hi ,
      After the newest MM update, the clock module is displaying UTC time, despite my RPi config set to EST.
      Interestingly, when I head to my MMs IP address from a separate computer, the clock is correct.
      Any ideas? Thanks!
      • BKeyportB Offline
        BKeyport Module Developer @drstang
        @drstang does setting the timezone config option adjust it ?
        https://docs.magicmirror.builders/modules/clock.html#configuration-options
          sdetweil @drstang
          @drstang another user had a similar problem with the calendar…
          rebuilt with a different pi and the problem went away…
          lets try this
          pm2 stop all  (or stop MM if you didn't use pm2)
          cd ~
          rm -rf .config/Electron
          pm2 start all
            drstang @sdetweil
            @sdetweil Thanks for the reply. Unfortunately - no luck. Still displaying UTC instead of EST.
              sdetweil @drstang
              @drstang thx… and you are certain the SYSTEM timezone is set to EST
              i can’t upload a pic of the config page on the pi… weird
                drstang @sdetweil
                @sdetweil Yep - did it several times to make sure!
                And the Mirror will show EST when I access it via a web browser!
                • BKeyportB Offline
                    drstang @BKeyport
                    @BKeyport thanks but unfortunately that does not work either - it results in the clock module not even loading (unless there was something else I should have adjusted)…
                    EDIT: I realized I changed the modules config initially, which didn’t work. But I changed the main config (duh - reading is key) and added the config/timezone line, which worked!! thank you!
                    BKeyportB S 2 Replies Last reply Reply Quote 0
                    • BKeyportB Offline
                      @drstang At least you can override it for now…
                        Richard238
                        Just updated my MM, clock is showing 18:13 when it’s 11:54…
                          sdetweil @drstang
                          @drstang I don’t understand this, the code does
                          		if (this.config.timezone) {
                          			now.tz(this.config.timezone);
                          which means it only uses its own config values, not the global config.
                          when I set it like this
                          			module: "clock",
                          			config:{
                          				displaySeconds:false,
                          				timezone:"UTC"
                          it correctly changed the displayed time from 08 (us central time) to 13
                          if I set it like this
                          	timeFormat: 24,
                          	units: "metric",
                          	timezone:"UTC",
                          it did not change the displayed time (as expected)
