    Default Clock wrong after update
    26 Posts 4 Posters 10.5k Views 4 Watching
      sdetweil @drstang
      @drstang thx… and you are certain the SYSTEM timezone is set to EST
      i can’t upload a pic of the config page on the pi… weird
        drstang @sdetweil
        @sdetweil Yep - did it several times to make sure!
        And the Mirror will show EST when I access it via a web browser!
        • BKeyportB Offline
          BKeyport Module Developer @drstang
          @drstang does setting the timezone config option adjust it ?
          https://docs.magicmirror.builders/modules/clock.html#configuration-options
            drstang @BKeyport
            @BKeyport thanks but unfortunately that does not work either - it results in the clock module not even loading (unless there was something else I should have adjusted)…
            EDIT: I realized I changed the modules config initially, which didn’t work. But I changed the main config (duh - reading is key) and added the config/timezone line, which worked!! thank you!
            BKeyportB S 2 Replies Last reply Reply Quote 0
            • BKeyportB Offline
              @drstang At least you can override it for now…
                Richard238
                Just updated my MM, clock is showing 18:13 when it’s 11:54…
                  sdetweil @drstang
                  @drstang I don’t understand this, the code does
                  		if (this.config.timezone) {
                  			now.tz(this.config.timezone);
                  which means it only uses its own config values, not the global config.
                  when I set it like this
                  			module: "clock",
                  			config:{
                  				displaySeconds:false,
                  				timezone:"UTC"
                  it correctly changed the displayed time from 08 (us central time) to 13
                  if I set it like this
                  	timeFormat: 24,
                  	units: "metric",
                  	timezone:"UTC",
                  it did not change the displayed time (as expected)
                  • BKeyportB Offline
                    @sdetweil Correction to your statement. timezone is set to null by default. timezone: null, - therefore, that if line would evaluate to false unless you override with timezone config item.
                      sdetweil @BKeyport
                      @BKeyport correct,
                      so a ‘forced’ timezone would not be set
                      this is the same code as before.
                      • BKeyportB Offline
                        @sdetweil said in Default Clock wrong after update:
                        This is what I was correcting. ;)
                          sdetweil @BKeyport
                          @BKeyport but he said,
                          changing it in the module config did NOT work
                          but
                          changing it in the GENERAL config DID work…
                          and it was NOT set in the original config he was using prior to the upgrade
                            sdetweil @BKeyport
                            @BKeyport said in Default Clock wrong after update:
                            I don’t understand…
                            what I said was
                            this module only adjusts the timezone when
                                config :{
                                    timezone: '??????',
                            in its module definition
                            NOT when its set in the global configuration, (before modules defined)
                            timeFormat: 24,
                            	units: "metric",
                            	timezone:"UTC",  <---  added this for testing, value NOT set in module config
                            so I don’t see what you are ‘correcting’
                              drstang @sdetweil
                              @sdetweil thats correct - when I changed timezone from ‘null’ to ‘America/New_York,’ the module did not work at all. When I went into the MM config.js and added the timezone line, it worked.
                              Which now I realize is also a bit frustrating because one of my modules also shows sunrise/sunset times, and thats still off (EST + 4 hrs).
                                drstang @sdetweil
                                @sdetweil and also, yes. prior to the upgrade, my general config was NOT set to a TZ prior to the upgrade. I
                                  sdetweil @drstang
                                  @drstang said in Default Clock wrong after update:
                                  correct… as there is no general timezone property
                                    drstang @sdetweil
                                    @sdetweil and what also confuses me is if I access the mirror via a web browser, the times are right!
                                      sdetweil @drstang
                                      @drstang I understand and agree with that…
                                      the clock code runs in the browser… so one can only assume that the
                                      moment code running in the browser is different between instances…
                                      BKeyportB 1 Reply Last reply Reply Quote 1
                                      • BKeyportB Offline
                                        @sdetweil Curious - are we still using Moment.js in default clock? I’ve heard issues relating with Moment and newer code - I think it might be failing to the point of no return.
                                          sdetweil @BKeyport
                                          @BKeyport AND it looks like we SHIP a copy… that is PROBABLY the problem
                                            drstang @sdetweil
                                            @sdetweil Makes sense - and certainly frustrating, as I realize I’m having issues with other modules that show times as well (showing sunrise/sunset, tide charts).
                                            Any suggestions on a fix - as it is essentially making my MM unusable since my ‘main’ modules rely on time…
