    Default Clock wrong after update
    26 Posts 4 Posters 10.9k Views 4 Watching
      sdetweil @drstang
      @drstang I don’t understand this, the code does
      		if (this.config.timezone) {
      			now.tz(this.config.timezone);
      which means it only uses its own config values, not the global config.
      when I set it like this
      			module: "clock",
      			config:{
      				displaySeconds:false,
      				timezone:"UTC"
      it correctly changed the displayed time from 08 (us central time) to 13
      if I set it like this
      	timeFormat: 24,
      	units: "metric",
      	timezone:"UTC",
      it did not change the displayed time (as expected)
      • BKeyportB
        @sdetweil Correction to your statement. timezone is set to null by default. timezone: null, - therefore, that if line would evaluate to false unless you override with timezone config item.
          sdetweil @BKeyport
          @BKeyport correct,
          so a ‘forced’ timezone would not be set
          this is the same code as before.
          • BKeyportB
            @sdetweil said in Default Clock wrong after update:
            This is what I was correcting. ;)
              sdetweil @BKeyport
              @BKeyport but he said,
              changing it in the module config did NOT work
              but
              changing it in the GENERAL config DID work…
              and it was NOT set in the original config he was using prior to the upgrade
                sdetweil @BKeyport
                @BKeyport said in Default Clock wrong after update:
                I don’t understand…
                what I said was
                this module only adjusts the timezone when
                    config :{
                        timezone: '??????',
                in its module definition
                NOT when its set in the global configuration, (before modules defined)
                timeFormat: 24,
                	units: "metric",
                	timezone:"UTC",  <---  added this for testing, value NOT set in module config
                so I don’t see what you are ‘correcting’
                  drstang @sdetweil
                  @sdetweil thats correct - when I changed timezone from ‘null’ to ‘America/New_York,’ the module did not work at all. When I went into the MM config.js and added the timezone line, it worked.
                  Which now I realize is also a bit frustrating because one of my modules also shows sunrise/sunset times, and thats still off (EST + 4 hrs).
                    drstang @sdetweil
                    @sdetweil and also, yes. prior to the upgrade, my general config was NOT set to a TZ prior to the upgrade. I
                      sdetweil @drstang
                      @drstang said in Default Clock wrong after update:
                      correct… as there is no general timezone property
                        drstang @sdetweil
                        @sdetweil and what also confuses me is if I access the mirror via a web browser, the times are right!
                          sdetweil @drstang
                          @drstang I understand and agree with that…
                          the clock code runs in the browser… so one can only assume that the
                          moment code running in the browser is different between instances…
                          BKeyportB 1 Reply Last reply Reply Quote 1
                          • BKeyportB
                            @sdetweil Curious - are we still using Moment.js in default clock? I’ve heard issues relating with Moment and newer code - I think it might be failing to the point of no return.
                              sdetweil @BKeyport
                              @BKeyport AND it looks like we SHIP a copy… that is PROBABLY the problem
                                drstang @sdetweil
                                @sdetweil Makes sense - and certainly frustrating, as I realize I’m having issues with other modules that show times as well (showing sunrise/sunset, tide charts).
                                Any suggestions on a fix - as it is essentially making my MM unusable since my ‘main’ modules rely on time…
                                  sdetweil @drstang
                                  @drstang I am away til Tuesday.
                                  not sure what a fix would be
                                    drstang @sdetweil
                                    @sdetweil I am a total novice at JS - but I fixed my modules by adjusting the configs - I incorporated moment-timezone.js and changed my code from ‘.local()’ to ‘.tz(America/New_York)’ Seems moment was having issues with the ‘local’ part of the code.
                                    A bit annoying, and I’m sure another way could have been used, but the modules are at least showing correct time now!
                                    • BKeyportB
                                      BKeyport Module Developer @drstang
                                      @drstang Ahh, perhaps a forgotten requirement. It seems clear we need to get rid of Moment.js
