    MagicMirror using the wrong time
    54 Posts 6 Posters 28.0k Views 6 Watching
      sdetweil @jasonumd
      @jasonumd just for the sake of fun testing
      in the script you use to start MM add
      export TZ=????
      where ??? is your timezone code
      add this line before the
      npm start
      line
      if you are using my install script with PM2, then the script located at
      ~/MagicMirror/installers/mm.sh
        jasonumd @sdetweil
        @sdetweil I’m not a linux guru. Added and rebooted. but I’m operating via Putty. Am I supposed to reboot while watching the screen and check for something?
          sdetweil @jasonumd
          @jasonumd just seeing if MM reports correctly
            sdetweil @jasonumd
            @jasonumd didn’t need to reboot… if using pm2, then
            pm2 status
            pm2 restart xx
            where x is the number of the line of the MagicMirror app
            or the name shown on that same line (I set it up as MagicMirror, others get mm as they started mm.sh)
            • 6
            • 6 / 6
