    MagicMirror using the wrong time
    54 Posts 6 Posters 32.4k Views 6 Watching
      sdetweil @blissb
      @blissb great info!!! thanks.
      this sounds like a bad moment lib.
        @blissb can you show me the list of active modules, in the order in config.js
        thx
          blissb @sdetweil
          Is there an easier way to get them other than just scrolling through the config.js?
          Modules in order:
          alert
          clock (correct after adding the timezone: option)
          calendar
          weather (Sunrise time is also 5 hours off - sorry if I failed to mention that earlier)
            sdetweil @blissb
            @blissb you could grep for ‘module:’
              blissb @sdetweil
              Doh!
                sdetweil @blissb
                @blissb I can’t tell you how many times I do that in a week! 😆
                how did you upgrade mm?
                  blissb @sdetweil
                  @sdetweil I have a script that moves the MM directory to backup, gets rid of the various package-lock.json files, then does a git pull && npm install --only=prod --omit=dev
                    sdetweil @blissb
                    @blissb ok. see these
                    and
                    I’m wondering if the npm install in the vendor folder failed. that is where moment is loaded
                    the fact that clock and weather and calendar are all messed up., is pretty interesting
                      blissb @sdetweil
                      I renamed the MagicMirror directory, and re-installed using the install script – iirc that’s what I used initially.
                      Sadly, no change.
                      Giving up for now – may poke at it more tomorrow. Thanks again.
                        sdetweil @blissb
                        @blissb would you be willing to share your config.js, send to me as a text file
                        same userid as here, at gmail
                        B 3 Replies Last reply Reply Quote 0
                          blissb @sdetweil
                          I think I can do that. I’ll send it after work.
                            blissb @sdetweil
                            You’ve probably seen it by now - but I’ve sent you the config.js.
                            Also, I saw some info about times being correct when viewed on a remote browser. I’ve tried setting the external browser in my “mm.sh” script to both midori and firefox (both are installed). Neither makes a difference.
                              blissb @sdetweil
                              If this is a red-herring / rabbit-hole, I apologize in advance. I haven’t done any javascript in 10+ years… all this is sorcery to me. :beaming_face_with_smiling_eyes:
                              I configured it to allow remote access via a browser on my desktop machine. On the pi running the newer (wrong time) version of MM, the browser displays the correct time, while the pi displays the wrong time. That’s kind of fascinating to me… clearly the browser is calculating the times on its own.
                                sdetweil @blissb
                                @blissb yes, someone else reported similar issue
                                the Midori/Firefox only work if the start line is changed in package.json
                                  sdetweil @blissb
                                  @blissb would you be willing to send me one of the extracted ics files
                                  curl -sL the cal_url >somefile.ics.txt
                                  because those are the ones causing the shift problem…
                                  I want to see how the ICS is coded
                                  same email ias the config
                                    blissb @sdetweil
                                    @sdetweil I sent the ics file – forgot to rename it with .txt. Let me know if I need to resend.
                                      sdetweil @blissb
                                      @blissb I have it. need to test.
                                        sdetweil @blissb
                                        @blissb i can’t recreate it on any system…
                                        if you’ve got time, could you make another sde card and reinstall mm using my script?
                                        and use your config.js
                                          blissb @sdetweil
                                          @sdetweil Just wanted to let you know, I’m working on this between other tasks. I’m also prepping for the Thanksgiving holiday tomorrow, so if I don’t get it finished tonight, it may be Friday before I get back with you.
                                            sdetweil @blissb
                                            @blissb no rush. when/if you have time
                                            B 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
